Headlight Question
Old Jul 19, 2006 | 03:16 AM
zxcv's Avatar
zxcv
Default Headlight Question
Is there a way to remove the clear plastic cover of our headlights? I want to paint the inside of my headlights to match the body, like this..
[IMG]local://upfiles/43055/F811C00B0B394F8491A035BC6568D4F9.jpg[/IMG]
Old Jul 19, 2006 | 03:18 AM
Jeremy's Avatar
Jeremy
Default RE: Headlight Question
Pop the hood and check it out. I can't remember right now(thanks to the alchohol), but I think you can manage something.
Old Jul 19, 2006 | 04:23 AM
Skoshi42's Avatar
Skoshi42
Yes there is a way to Paint the inside of the headlights, this is a rough list of things to do... you will need to research on your own the proper procedure on doing this, I know people on MSPROTEGE.com they have a how to section on how to paint headlights..
1. remove headlight assembly
2. bake for 20 minutes at 200 degrees
3. carefully pry apart the clear plastic lense
4. Seperate the inner headlight from the trim piece
5. sand down the trim piece and then primer
6. Use a good high heat spray paint
7. let both headlights dry, then reassemble
8. Use some good quality Butyl Rubber to adhere the clear lense to the headlight assembly
9. Reinstall the headlight, bumper, etc...
10. Enjoy!!
Old Jul 19, 2006 | 04:36 AM
Jeremy's Avatar
Jeremy
What, no apatizer?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
UrS4
Sep 30, 2015 10:13 AM
Drastang
Sep 30, 2015 03:48 AM
treesloth
Sep 28, 2015 07:03 AM
