filler up
Old Aug 4, 2006 | 10:07 AM
Mansmadlogic's Avatar
Mansmadlogic
Default filler up
any one have problems filling there car up? If i run my car almost to empty then fill it up it will only take half a tank and thats it
usually ill drive it for a day then fill it the rest of the way up. but any one else have this problem
Old Aug 4, 2006 | 10:17 AM
Mansmadlogic
Default RE: filler up
crap not related to this but I have a ford van aswell as my stang and my van has a recall so i have to take it in
Old Aug 4, 2006 | 10:51 AM
robc@pdpf.com's Avatar
robc@pdpf.com
Did it 2 times to me. Dealer said I was opening the gas cap to quick. I turn the cap slow and bleed the pressure of.....hasn't happened since.
Old Aug 4, 2006 | 11:18 AM
28HopUp's Avatar
28HopUp
MF Administrator
You didn't say what year your Mustang is, but check out the following link. It shows a list of Technical Service Bullitins TBS's (the link can also be found at the top of this page in the blue band). Search for your year Mustang, and check the TSB's for the fuel system. Your problem might be included in a TSB. There have been quite a few similar complaints.
Old Aug 4, 2006 | 11:37 AM
Railrider's Avatar
Railrider
This problem is addressed in the following TSB
2005 Ford Mustang
Bulletin #: 0548
Sequence #: 10014651
Date: 06/07/2005
Component Name: 090000 fuel system, other
Make: Ford
Model: Mustang
Year: 2005
Summary: Fuel fill slow, or difficult to fill.
See your local ford dealer for help.
Old Aug 4, 2006 | 03:05 PM
petepete's Avatar
petepete
yea tsb fixes it but make sure you goto a good dealership or else you get ownt in the butthole
Old Aug 4, 2006 | 03:23 PM
HurricaneStang's Avatar
HurricaneStang
I had a similar problem, I'd go to fill up and it wouldnt even take it but a couple of gallons maybe 2-3 the rest would just run down the side of the car and squirt out. I just took it to the dealership and they replaced the whole gas tank and now its fine.
Old Aug 4, 2006 | 09:39 PM
JimC's Avatar
Super Moderator
The service manager at my dealer said that if you take the nozzle and turn it upside down it will usually take care of it. I run into this problem once in awhile - I have the 2006 so it appears to be differences between gas stations and the pressure they deliver the fuel. My car wasn't covered by the TSB.
Old Aug 5, 2006 | 09:52 AM
Mansmadlogic
sorry i have an 05 satin silver working on getting some pics
but i have noticed that different gas stations have different effect but thanks for the tips everyone
Old Aug 5, 2006 | 11:13 PM
Skoshi42's Avatar
Skoshi42
I have this same problem!!, I cannot put chevron gas!! I only can use shell.... I think it has something to do with their nozzles... I told my dealership about the problem and they didnt know what I was talking about... GRR!
