What's a safe RPM range for cruise?
The car seems to sound happiest between 2200 and 2500 RPM for level cruise. Is it OK on the engine to cruise at 1800 or even lower? If so, I'll gear up to 5th more often to save gas.
Ken
Ken
RE: What's a safe RPM range for cruise?
I usually cruise around 1800 seems ok to me if you read the manual it gives you shift points so you can get the most gas mileage of course cruising at that low rpm you will have no acceleration.
Interesting topic, here’s something else… I find closer to 3000 rpm the car shifts a little smother, easier. Although this shift point is totally exceptional at cursing speed around town it seams like the revs are a little high. I usually shift just a little under. Anything under this and I find you have to be pretty precise for the smooth shifts. What do you all think?
ORIGINAL: blackNchrome05
I have an automatic... I'm in 3rd gear at 16 mph... ?
ORIGINAL: scrming
yep, at light/part throttle our automatics are upshift happy.... I've personalized mine for my driving style... I don't come out of 1st gear at light/part throttle until 18 MPH! LOL!
ORIGINAL: jittie
Did you do that with your Xcal? Do you have to set the mph for each gear when it will shift, or is there an option to have it shift more aggressively?
ORIGINAL: scrming
