How can you burn out in the V6
RE: How can you burn out in the V6
I dont get it then. With the exception of the muffler everythings stock and i cant do it. I hold the brake and then gas it but does nothin but raise rpms alil bit. Even tried to barely get going then hit brake but didnt do anything either. This sucks
too bad man, i feel for you. i have a stick and i love it. i can burn the tires out all the way through third gear. but like they said just hold down the brake and mash the gas and release the brake. make sure you turn off the traction control if you have it. my first car was 1996 auto dodge avenger. it only had a 3800 v6 and it burned out pretty good. it possible in a auto but if you want that burnout feeling, just get a stick.
ORIGINAL: HurricaneStang
It appears that for 06, Ford might have raised the torque limiter a bit....
But I was once like you... I couldn't get my tire to spin even power braking! Installed an X-Cal2.. one legged burn outs all day! LOL! Then put the 4:10's and Track-Lock in and:
http://www.tammyandjohn.com/Mustang/...ng_burnout.wmv
scrming Date 8/28/2006 3:15:38 PM
The 2005's auto's have a torque limiter that prevents you from making enough torque to really break the tires loose... Pick up an X-Cal2 for $400 and it will remove it... You will still need to power brake a bit but you'll be doing burnouts all you want...
