Maintenance
Old Oct 23, 2006 | 12:15 AM
DragonPL's Avatar
DragonPL
Default Maintenance
My car is 7 months old and I just hit 20,000 miles on the odometer. The only mechanical maintenance I've been doing is the routine oil changes, is there any other maintenance things I should be looking into..?? car runs fine.
Old Oct 23, 2006 | 12:28 AM
phunnyguy's Avatar
phunnyguy
Default RE: Maintenance
i would go to the dealer and have them perform a 20,000 mile check up......i had a 10,000 mile check up which i do a check up evey ten to 15 thousand miles. i change the opil between 3 and 5 thousaqnd miles.......you probably could use a tire rotation at the least...
hope this helps.
Old Oct 23, 2006 | 12:32 AM
mdlesk's Avatar
mdlesk
I would have your fuel filter checked as well...speaking of which I should get that done seeing as how I have 39,000 miles and haven't got that done
Old Oct 23, 2006 | 03:19 AM
ilduce321's Avatar
ilduce321
I have a maintenance book from Ford and from my dealership. Basically, if you haven't done anything but oil changes, you should do a wheel alignment, change the cabin air filter (do this yourself, you will easily pay over $100 to have this done for you), maybe replace the fuel filter, check your fluids, rotate the tires, check your air filter, the routine stuff.
I've had mine for 7 months and just hit 15k. I'm doing an alignment at 20k, fuel system cleaning at 25k, and then of course the 30k service is a BIG one. If I have the 30k service done at the dealership, including their "recommended" services, it would cost about a $1000 to do. The regular 30k interval at my dealership is $500. I plan on spreading out the recommended services over time.
Old Oct 23, 2006 | 10:45 AM
BHRS's Avatar
BHRS
What brand of oil are y'all using? I have seen Royal Purple, Mobile 1, and some others listed on this forum.
dubarado
Dec 23, 2015 01:16 PM
piotrek53
Oct 13, 2015 06:54 PM
Sep 25, 2015 06:42 PM
motown girl
Aug 28, 2015 08:21 AM
Nexuia
Aug 25, 2015 04:06 PM
