sct II problem
Old Oct 26, 2006 | 04:26 PM
craezjo's Avatar
craezjo
Default sct II problem
how do you tune the mustang i tried to tune it but when it was done i stepped on the gas to rev the engine but nothing happend wats wrong with the car now. and how do i get the tuner to work
Old Oct 26, 2006 | 05:47 PM
28HopUp's Avatar
28HopUp
MF Administrator
Default RE: sct II problem
ORIGINAL: craezjo
You weren't very detailed in exactly what your car is doing. It could be related to the car needing to relearn the drive-by-wire aspect of the gas pedal. Here's a link -
https://mustangforums.com/m_1826949/tm.htm
Hope this helps!
Old Oct 26, 2006 | 06:27 PM
craezjo's Avatar
craezjo
well when i start the car the check engine light stays on and the wrench light is on which means something about the electronic throttle body thats pretty much all i kno before i tuned it with the cai it was runnin normal then i tried to tune it and that happend and i tried to put it back to stock but it hasnt worked. i tried like 10 diff ways to return it too stock and nothin work.
Old Oct 26, 2006 | 07:36 PM
Rupp's Avatar
Rupp
Which CIA? Whos tune? Maybe step by step on how you loaded the tune?
Old Oct 26, 2006 | 08:35 PM
craezjo's Avatar
craezjo
steeda cold air intake, with americanmuscle.com tune when i bought the sct II, and i did read the directions and did what they said.
Old Oct 26, 2006 | 08:37 PM
Pyrat's Avatar
Pyrat
Craezjo, when you say "i tried to tune it", exactly what do you mean? Which tuner are you using, and who did you get it from?
Old Oct 26, 2006 | 08:42 PM
Pyrat's Avatar
Pyrat
Ok, that answered my questions. Try reloading the stock tune from the SCT and see if your problem corrects. If not, remove the CAI and reinstall the stock intake and see if that fixes it. Assuming it does, then load the tune and see what happens. If all is well, try installing the CAI again and see what happens. Theoretically the problem should reoccur at this point. This sequence should let you determine where the problem is, CAI or tune. Depending on where your problem shows up, contact the appropriate manufacturer and see what they can do.
Old Oct 26, 2006 | 09:08 PM
NickSezz's Avatar
NickSezz
I don't really know much about this topic, but if all else fails try to take off the negative battery cable for a few min to shut the computer down. Then put it back on and try to load the stock tune. Might have just bugged the computer I don't really know.
Old Oct 26, 2006 | 09:10 PM
craezjo's Avatar
craezjo
i also had the gms 70mm throttle body put in too so i think it might be the throttle body and i think i also blew the pcm. i think i just have to re adjust the springs in the throttle body. i heard that people have been havin problems with the throttle body and cant get it to work right. im hoping its just the throttle body though, but i drove it about 3 blocks without any tune with the bigger throttle and cai then i tried to tune it and thats when the car went into that "limp-home" mode.
Old Oct 26, 2006 | 09:14 PM
petepete's Avatar
petepete
you said you loaded the tune and then press the pedal. Was the car on (engine running) when you loaded the tune?
