aux???
Old Nov 13, 2006 | 03:52 AM
bw1128's Avatar
bw1128
Default aux???
how do you use it? it that for a ipod? how can i hook mine up?
Old Nov 13, 2006 | 08:26 AM
MdnytRider's Avatar
MdnytRider
Default RE: aux???
Get this:
http://www.crutchfield.com/S-XFpYV29...r&i=469FRD4AUX
Old Nov 13, 2006 | 11:58 PM
JimC's Avatar
Super Moderator
Default RE: aux???
According to my Sirius information, I only need a cable to plug in the back (RCA type I believe) - I should know this weekend when I take things apart, but Best Buy agreed it was just a cable connection.
Old Nov 14, 2006 | 01:53 AM
Pyrat's Avatar
Pyrat
Default RE: aux???
JC, I've heard this isn't the case with the Shaker systems, but would be very interested in what you find when you pull the unit. Would you please photo document the operation? It would, undoubtedly, be very helpful to anyone on the forum thinking about either adding a Sirius, XM radio or iPod connection to their system.
Old Nov 14, 2006 | 07:22 AM
TTSRACINGWORLD's Avatar
TTSRACINGWORLD
Default RE: aux???
There are no RCA jacks in the back. It's a din plug and I think the Sat radio goes between the plugs. You would have to have a Ford Sat radio set up for it yo work. I have XM and have to go threw the FM Mod and it sucks. My Ipod is hookup to the Ford jack that goes threw the ant. (it's the same as a FM Mod and it sucks.) Ford is coming out with a true hookup for the AUX button to be released near April 2007. I can't wait.
Old Nov 14, 2006 | 09:33 AM
Black06stang's Avatar
Black06stang
Default RE: aux???
I have the auxiliary input adapter from discountcarstereo.com (around $100) and it works perfectly. You plug it into the rear of the radio, connect it to a power source, and I ran the headphone cable to the center console. It should work with anything that has a headphone jack on it.
Old Nov 14, 2006 | 01:14 PM
pperin's Avatar
pperin
I ♥ Acer
Default RE: aux???
where would I find info on how to remove the unit from the dash?
Old Nov 14, 2006 | 02:21 PM
68XR7's Avatar
68XR7
Default RE: aux???
As you know, the 2005 was not offered with the Aux. input feature. This was a big deal to me, because I like to use an MP-3 in the car. I don't like having all of those CDs laying around. I went to my local stereo shop and they installed an interface device that came from the Peripheral company. The unit is completely concealed in the console. There is a small, female jack, mounted inside of the arm rest box. Just like on the '07 Mustang. To use the device, all you have to do, is plug the MP-3 into the female jack, turn on the radio, press the Aux. button and the MP-3 plays thru the stereo. I am pretty happy with the way that it works, but if I was going to complain about anything, it would be that the signal is kinda weak. I mean, it works OK, but you need to turn the MP-3 volume all the way up, then turn the radio volume up too. I wish that the unit had a little more gain, or something. Otherwise, it is a good solution to the Aux. problem. I Will include a link below:
http://peripheralelectronics.com/home.asp
Old Nov 14, 2006 | 03:48 PM
Rrruss's Avatar
Rrruss
Default RE: aux???
I have the FRD04 that was referenced in one of the posts above.... it has an output level adjustment on it to balance the audio level when switching from the Aux input to normal radio options (CD, FM, AM). If I remember right it was in between the RCA inputs on the unit. So far I have been happy with it's performance.
Old Nov 18, 2006 | 03:12 AM
linesma's Avatar
linesma
Default RE: aux???
I recently installed an after market stereo into my car. It took me about an hour to do. I have the sheets thats show you how to remove the factory radio and speakers. They are in pdf format and I will e-mail them to you if you want. Just give me your address and it will be done.
