weight reduction
Old Nov 27, 2006 | 11:44 PM
Jerseyfury2's Avatar
Jerseyfury2
Default RE: weight reduction
309lbs....not bad haha. My thinking is that this kind of lightening isn't even worth it unless you're all out dragging and nothing but IMO
ORIGINAL: rygenstormlocke
Friend of mine posted this over at Mod Fords.....
Shaker 1000 headunit, speakers, rear speaker brackets & sub - 56.4lbs
driver and passenger door panels - 12.8lbs
plastic backseat side panels - 5.0lbs
plastic c-pillar panels - 3.0lbs
back seat - 14.8lbs
carpeting and floor mats - 22.6lbs
sound deadening material - 29lbs
spare tire & wheel - 27.0lbs
jack tools and jack, - 5.4lbs
cardboard trunk tire cover - 8.2lbs
A/C compressor, condenser, reservoir, & some piping - 31.2lbs
windshield wiper reservoir (full of fluid), bracket, & associated tubing - 9.0lbs
glovebox - 4.6lbsplastic driver and passenger kick panels - 1.6lbs
center console - 12.3lbs
front sway bar - 19.5lbs
passenger seat - 51.2lbs
Old Nov 28, 2006 | 01:53 AM
ranebowcyxx's Avatar
ranebowcyxx
BadAss 13-sec N/A 4.0L
ORIGINAL: fazm
bmr makes good weight reudctioon products.
by the end of the week, i will have most of them installed.
i already have the bmr radiator support/sway bar delete.
i ordered the k member and non adjustable a-arms
all 3 will give me around a 50-60lb weight reduction
I thought the BMR k member was a V8 only part, is this a new one? Because this is something that is on my short list if so.
By the way, do you miss the front sway bar?
Old Nov 28, 2006 | 02:06 AM
fazm's Avatar
fazm
ORIGINAL: ranebowcyxx
ORIGINAL: fazm
the bmr piece fits both v6 andd gt models, as the factory shares the same part #, even the motor mounts are the same motor mounts.
i dont "need" my front sway bar, i dont make hard turns, or anything like that, so i guess i dont miss it.
baddog671
Jul 26, 2016 01:20 PM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
jar_are_red
Sep 24, 2015 07:03 AM
Sep 8, 2015 11:50 AM
