Reving while in Neutral?????
RE: Reving while in Neutral?????
i wish i COULD have gotten a manual my mom sucks at driving stick and thought that it woudl be a safety isssue for me, but little does she know i can drive a stick better than anyone in my family lol. pisses me off
Somewhat connected to this, has anyone else noticed this odd behaviour when decelerating.
Maybe it's just the way I drive but, if I am slowing for a red light, say, and change down from 3rd to second and then basically run out of road before the clutch is all the way up (sounds strange but I'm sure you stick-shifters know what I'm talking about!), when you push down the clutch the revs drop almost to a stall and then recover. At first i thought it was the clutch sticking but the pattern is too exact every time - it's clearly and ECU issue.
The only oddity I've experienced with downshifting and RPM change is when the car is cold, going downhill and downshifting, the compression goes away until I push in the clutch and let it back out again. Doesn't do it when it's running at temp though. My thought is if it only does at certain times under specific conditions it's probably not worth worrying about unless it becomes more frequent or worsens in some way.
Mine for the first time yesterday did this while in gear...Usually it is once I put it in neutral, but yesterday I was stuck in horrible traffic due to a wreck and we were creapeing along about 5 mph, and suddenly my car starts going faster and faster and revvs it up while in 1st gear up to about 2k rpm, had to hit my brakes, but it was the first time that it had done that...And at this point in time the engine was already warm, since I had been sitting there for 45 min....So I don't know if maybe it is time to get concerned about this issue since it has begun happening while in a low gear
[IMG]local://upfiles/44060/8A7D091373AE41AA8CDAEE89C2D2E80F.jpg[/IMG]
This happened to me for the first time yesterday also. My car took an extremely long time for the idle speed to go down. After you come to a stop, the RPM'swould eventually come down, but this was very frustrating to deal with on a 28 mile commute in Houston traffic. Itall most caused me to run into a car in front of me that was stopped at a stop sign. The RPM's were so high when I took my foot off the accelerator and pushed the brake, it almost pushed me into the back of the car in front. I had to quickly apply the clutch to stop in time. Today it's not doing it. I'm going to bring mine in to the dealership also.
ORIGINAL: Adian
i learned this in school, and in fact all manual cars do this (cars that are OBD2)and some more than others
whats hapening is that the computer is sensing a high wheel speed with no input.. but the car knows its rolling, and at some point you might want to throw it in gear and get on the gas, you wont have throtle lag, and responce will be up!
My pony, for the second time,
My wife started from a stopped position and the car started reving wildly. At first I could not get the vehicle to duplicate the action. about a month later I was driving the car reasonably aggressive running through the gears. I pushed the cluth in and shot it into third. The gas pedel dropped out from under my foot and went to the floor all as I was hard into a corner and needed the controll. I almost lost it into a field and depressed the cluth. The car started pegging off the rev limiter and I killed the ignition. I had to pry the pedal up with my foot before restarting. She's in the dealers hand right now and I hope they have a good explination. Scary s&*#!
