Tri-Bar Pony Install On Grille??
http://www.v6mustangstuff.com/05Grills.htm
2nd grille down on the right...
how would I put the 05+ fender pony emblem on there. just use the d/s tape? or do I use a bracket. Thanx
RE: Tri-Bar Pony Install On Grille??
I'm having the same problem as you are. Afixer said he made sum type of bracket out of shink tube and another guy told me he used the tape. i tried the tape. didnt work. my body guy says maybe glue. good luck wit it. if you figure it out can you put a post up of how you did it? I have been trying for a minute now.
I have a tri-bar emblem on my stainless steel grille.. I know I might get some crap for this, but I cleaned the adhesive off of my tri-bar, washed it up with detergent and rubbing alcohol, cleaned the grille doing the same, then used "gorilla glue" and pressed it on there for about a minute and let it sit overnight. I've had it on the car for about 2 months now and it's still sitting strong
why would u get crap...that's pretty good idea..
ORIGINAL: Ry05Stang
hey Ry, i was at my job today and saw the gorilla glue and thought the same exact thing lol but i dont have a billet grille i have the grille wit the center fog lights by SSE so it might not stay on, i dont know.i guess its worth a try right?
Afixer, I dont think your adapter idea will work with the thin black grille im looking at. (no thickness)
The gorilla glue seems good...but permanent.
