HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Mar 2, 2007 | 10:24 PM
ponyskunk06's Avatar
ponyskunk06
Default HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
HELP I JUST GOT BACK IN FROM INSTALLING A MMR THROTTLEBODY SPACER AND HIGH FLOW INTAKE TUBE AS WELL AS PUTTING ON A TUNE I DID ALL THE STUFF BEFORE I DID THE TUNE AND THEN I LOADED THE TUNE AND MY CAR WONT WORK IT STARTS UP BUT THEN CUTS OUT I DONT KNOW WHATS WRONG AND ITS DARK SO I KNOW ITS NO GOOD TO BANG AROUND IN THE DARK DOES ANYONE HAVE ANY IDEAS
Old Mar 2, 2007 | 10:29 PM
tedBalog's Avatar
tedBalog
Default RE: HELP!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Make sure you're running the proper tune, make sure you connected everything back, MAF to be specific.
Old Mar 2, 2007 | 10:45 PM
MrSandman's Avatar
MrSandman
Make sure you reconnected the MAF sensor plug.. and that vinyl tube.
Old Mar 2, 2007 | 11:02 PM
chrisc's Avatar
chrisc
the tune could be screwed up. that happened to me. when you load it on, it will make a weird noise, and when you try to start the car it will make a weird noise from a speaker (or something) under the hood.
if that is the case, the stock tune should still work. Talk to the person who sold you the tune, if they are good they will send you another one
Old Mar 2, 2007 | 11:58 PM
wolfey2k's Avatar
wolfey2k
After you check everythingand it's okay, reload the same tune then try it.
Do not unplug the tuner until you're instructed to do so.
Also if it says to unplug the unit now and there is also a 'contiune' button showing like with the Diablo's, DO NOT PASS GO! In other words do not select continue, just unplug the unit like it says to and you should be okay.
Failing that, you probably have a corrupt tuner. Time to call tech support.
Old Mar 3, 2007 | 01:19 AM
fazm's Avatar
fazm
step 1: turn off ur caps lock key
step 2: go through and double check everything, listen for vacuum leaks, and try unloading and reloading the tune.
Old Mar 3, 2007 | 02:56 PM
ponyskunk06
ok thanks everyone i fixed the problem but im kinda embarresed to say what was wrong
Old Mar 3, 2007 | 02:59 PM
ponyskunk06
eh screw it when was reassmble the intake with the high flow tube i accdentally put the collar with the MAFS on backwards everyone feel free to point and laugh. I wonder if i have a blonde relative in my family somewhere
Old Mar 3, 2007 | 03:18 PM
NickSezz's Avatar
NickSezz
hahaha
