HAS ANYONE EXPERIENCED STALLING???
Old Mar 13, 2007 | 11:11 PM
hazestang's Avatar
hazestang
Default RE: HAS ANYONE EXPERIENCED STALLING???
another possibility is if you have dual exhaust. if the exhaust pipe is close to the fuel electrical cluster above the axle on the driver side, it will overheat the sensor and cause a trip. when it cools down it will work again. When it first started on my car, it was intermittent(sp), finally the car just stopped in the fast lane doing about 90. Had it towed to the shop and the fuel reset button on the driver side kick plate was fried. If it stalls pop that cover and hit the red button, it will reset, but fix the issue asap.
Old Mar 17, 2007 | 04:46 PM
jaded seconds's Avatar
jaded seconds
i've also experienced a stall once cruising in neutral to a stop. it stalled when i was braking right before the red light. it's brand new, only 600 miles on it and it's only happened once. i just restarted the car. it's kinda freaky, because we don't want anything bad to happen to our new cars.
it happened when i had a new axle back installed. but after that stall happend i've put on roughly 200 miles.i'm gonna keep an eye on it to see if it ever happens again.
CS2007
Jun 25, 2019 09:45 PM
Dathan
Oct 5, 2015 05:52 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
trashxtrash
Sep 20, 2015 10:49 PM
