Supercharger PSI
Hi im thinking about getting a S/C eithe the paxton or the procharger and i have a couple of questions
1. whats a "safe" PSI to be running
2. should i spring for the intercooler
3. can our v-6 engine handle running rougly 320 HP
4. have any of you had any werid issues with either the Pxton or the PROcharger
thanks
thanks
safe psi is higher than 6 if you ahve the intercooler. Im running 10psi but some are running 12 and 14 psi no problems. On a procharger though it makes more hp most of the time than the other s/cs so you can run at less boost and make more power.
ORIGINAL: ponyskunk06
thanks
thanks
2. yes.
3. at the wheels or the crank? really...yes to both.
4. I have heard tons of bad things about procharger recently, but the paxton is basically the vortech with a slightly different head unit, so i would say the paxton is reliable.
Get your flame suit ready for the Pro Charger guys LOL!
ORIGINAL: 8cd03gro
1. depends on the tune/specific setup, but if you are using it as a daily driver, might as well stay under 10 just for safety.
2. yes.
thanks
thanks
2. yes.
ORIGINAL: beaustang
ORIGINAL: 8cd03gro
2. yes.
thanks
thanks
2. yes.
what PSI does the paxton/vortech unit normally put out and how can i ncrease it
