Changing Headlight Bulbs??
Old Apr 2, 2007 | 02:56 AM
v6VenoM's Avatar
v6VenoM
Default Changing Headlight Bulbs??
Ok now maybe this is a stupid question, but I have never changed the bulbs, but when I changed my headlights I had to remove the bumper partially on each side. Is there an easier way to change the bulbs? Does anyone know?
Old Apr 2, 2007 | 03:00 AM
cvz_finezt's Avatar
cvz_finezt
Default RE: Changing Headlight Bulbs??
yes there is an ez way to do it. the bulbs are accessed right under the hood. yea man its lik a 5 minute job. the hardest part i found was unscrewing the bulb assembly, cuz the one on the pasangers side is in a lil bit of a tight spot. but u dont need no tools.
Old Apr 3, 2007 | 09:45 AM
SOHCman's Avatar
SOHCman
ORIGINAL: v6VenoM
Not a stupid question.
Replaced mine with Silverstars last week.
The thing to remember is to leave the old bulb in and remove the wiring plug first!
You need to squeeze the little prong on the plug and using a LARGE flatbladed screwdriver (small won't work) TWIST GENTLY and the plug will separate from the bulb.
A small screwdriver doesn't apply an even force and will twist the plug improperly.
Mine came off with a slight "snap" as they had been on for 40,000 miles and they were sticky & sandy. Newer cars should be easier.
Makesure to go back and peel off the old rubber gasket where the old bulb was.
Mine were RED. The gaskets fit INSIDE the little ring around the bulb. The new ones are gray.
I have some photos I'll post when I get home tonight.
Don't touch the bulb with your fingers as the oils on them can cause the bulb to break when it is powered up!
SOHC
Old Apr 3, 2007 | 11:55 PM
GstangT's Avatar
GstangT
ORIGINAL: SOHCman
ORIGINAL: v6VenoM
SOHC
Silverstars? I was looking for silverstars but my local Kragen said they didn't make it for the mustang. What bulbs are you using?
Old Apr 4, 2007 | 08:29 PM
SOHCman's Avatar
SOHCman
ORIGINAL: GstangT
H13ST
http://www.bulbman.com/index.php?mai...;keyword=h13st
Got em in a few days.
SOHC
[IMG]local://upfiles/62156/2788001FE6D5402E8E458E2E7498E647.jpg[/IMG]
Old Apr 4, 2007 | 08:37 PM
SOHCman's Avatar
SOHCman
ORIGINAL: v6VenoM
Open the hood and look directly behind the headlight housing. The bulbs are there.
Not much room to maneuver.
Make sure to take the gasket off the housing before installing the new bulbs.
They go in 1/4 turn clockwise (looking from the back).
SOHC
[IMG]local://upfiles/62156/DCC9B323DDA647839157FC3766A37405.jpg[/IMG]
[IMG]local://upfiles/62156/2E75CF66D72E445E8CCE198E3E460ED3.jpg[/IMG]
Old Apr 4, 2007 | 11:40 PM
v6VenoM's Avatar
v6VenoM
I seen it. thanks for the input. appreciate it.
StalkerGT
Nov 28, 2015 03:09 PM
kawiguy827
Sep 22, 2015 10:52 AM
Mobiusone stang
Sep 7, 2015 08:46 PM
amandahchase
Sep 3, 2015 10:09 AM
