8.8 rear vs Tlok 7.5
#21
RE: 8.8 rear vs Tlok 7.5
scmring is an auto, so the shock isnt there like a manual car. flapjack is a manual... we will see how long it holds
#22
ya, pretty much how it goes.
if ur a manual, and ur gonna drive like me lol, you get the 8.8
if ur an auto, with the stock stall, the 7.5 should be plenty good, unless you are doing a bunch of 100+ shots of nitrous like scrming lol
#23
The reason Ford upgraded the GT to an 8.8 diff in 1986 was because of diff failure with a 285 ft/lb
V-8 engine. The 7.5 is a weak link and anyone with serious performance aspirations wouldn't spend a dime on upgrading one. btw the S197 GT's 8.8" already has 31 spline axles and the LSD TSB was due to improper friction modifiers added(or not)to the diff lube at the assembly plant from my understanding. If you're super serious then the big daddy 9" Ford diff is the only real solution.
#24
Anyone know if the GT automatic drive shaft is compatible with the V6 automatic and 7.5 rear end?
Is the GT driveshaft balanced better / tougherthan the V6 driveshaft?
Thanks ahead of time!
Wolfey2k
Wolfey2k
#25
ORIGINAL: wolfey2k
Wolfey2k
Wolfey2k
#26
so i was wondering where and how much it costs to put a t-loc into my car. i would love to do burnouts with both wheels and i was wonderin if anyone had any advice because i am completely in the dark on this subject?
Matt's 95 Stang
10-05-2015 07:16 AM
