Wierd Sounds? From Mod's lol!
ok i Installed JBA Headers and i have alot of vibration no big deal ,.... but i get this wierd like metal hitting metal sound from the steering wheel? any idea what this is ?
Also is anyone happy with the sound jba shorty headers added ? mines at high speeds or high acceleration sounds like the engine is straining ? I hear more idle tho , That's allways good ! ? i need help lol please
RE: Wierd Sounds? From Mod's lol!
You've complained about the headers making noise before, did you take the suggestions given an tighten them down again? If not, DO IT. That noise might be the headers as well.. Did you just start hearing it? Was it happening before you installed the headers? Is it a constant noise?
Gotta give more details..
it made diffrent noise before from the engine bay they where the headers themself , I had it tightened and they went away now im geting like a loose sound in the steer wheel i tryed adjusting it up and down and even PUNCHED it acouple times lol nothing works !?
Since you have an 05 it sounds like the "popping" noise referred to from an early TSB. It's coming from the coil spring catching when turning the streeting wheel. They have this coil spring isolator(plastic, rubber etc. tube that slides onto the lower front coil spring) Ford part #8484 you'll have to get the rest of part # at the dealer. This could be your trouble or something else. Pull a wheel and check it out. Or maybe the isolator slid up causing the noise again. Maybe the TSB is still in effect and get it fixed for free.
