just installed fog lights on the v6
ok so my dad bought me some fogs back in dec..and it was nice out so around 6 i started to install them..finished around 9:15..but still gotta drill the switch in and also thinking about putting the grill back on....here are some pics..let me know what u think
RE: just installed fog lights on the v6
ORIGINAL: afixer
drill the switch ? why not just use the gt switch and keep it clean?
well the gt switch can be got at the dealer or from a few of the guys on the forums that work in ford parts. its obviosly more money that way but looks stock the only this is how its wired. if you are using a relay (and i hope you are) you would need to set it up so that the ground wire is what trips the relay and not a hot wire. this i due to the fact that the gt switch output is a ground not hot. if you are not sure how to do this and are willing to spend the 40 bucks that the switch will prob cost . you should be able to do a search for the wire diagram i posted on this a year ago and many time since i did this on mine, if you cant find it let me know and ill post again . i have helped plenty of guys with this its pretty easy and very clean. im just not a drill the dash kind of guy if its not needed.
If you put the grill back on will you still get any light output? I was thinking about doing something like that but didn't want to cut the grill around the fogs.
