Window Problem
Old May 7, 2007 | 10:53 PM
jasong61's Avatar
jasong61
Default Window Problem
Alright,
My battery died in my 2005 mustang. Something that is kinda crappy is that when the battery is dead you can't put the car in neutral. Thats one problemI have had. The big problem is that after charging my battery, now my auto roll-up feature on my window doesn't work on the driver side. When i get out it lowers, but after closing the door it won't go back up. Anyone have the fix for this, or amI needing a trip to the dealer?
Old May 7, 2007 | 11:01 PM
mdlesk's Avatar
mdlesk
Default RE: Window Problem
That happened to me as well. The issue went away after about 1 and half days. It sucked cause it would auto down, but not auto up. Everything went back to normal though.
Old May 7, 2007 | 11:04 PM
Mystang07's Avatar
Mystang07
To fix this problem, just start the car and hold up on the window toggle for about 2~3 seconds (with the window closed), should take care of it.
Peace!
Scott
Old May 8, 2007 | 03:54 PM
tilt's Avatar
tilt
there is window reset insturctions in the manual I know.
Old May 8, 2007 | 04:38 PM
MrSandman's Avatar
MrSandman
[sm=icon_rtfm.gif]
ORIGINAL: jasong61
Alright,
Old May 8, 2007 | 05:25 PM
Erdrickk's Avatar
Erdrickk
as others say....its all in your manual...you just need to reconfigure the window..takes 2 seconds
Old May 8, 2007 | 06:32 PM
dotsonian's Avatar
dotsonian
You can put an auto in neutral when the battery is dead. It is in the manual too. (hint: lift up the little plate on the right side of the shifter housing)
Some older electronic transmissions do not have this feature, but ours do.
Old May 8, 2007 | 06:39 PM
05MustangSally's Avatar
05MustangSally
ORIGINAL: dotsonian
Yes, some automatics in newer cars have this feature. Unfortunately, I've known some who can't even can't the thing open because you have to use a key. But that's why it's good to have a manual trani
Old May 8, 2007 | 06:46 PM
dotsonian's Avatar
dotsonian
ORIGINAL: 05MustangSally
ORIGINAL: dotsonian
true manuals are great for that, and push starting.
Our autostake a key too, the ignition key.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
robjh22
Suspension
Sep 8, 2015 12:47 PM
zanemoseley
Sep 6, 2015 12:58 PM
5.0 kevo
Sep 3, 2015 06:24 PM
