GEARS
Old May 21, 2007 | 10:28 PM
SOHCman's Avatar
SOHCman
Default RE: GEARS
ORIGINAL: urnamethere
not to thread jack but i am also looking at gears and a t-lock my buddy told me to go with 3.73 what exactly do you see with those performance wise
With T-LOK you will get TRACTION, TRACTION, TRACTION, TRACTION!
You will like itvery,very,much!
SOHC
Old May 21, 2007 | 11:27 PM
MlissaG's Avatar
MlissaG
Default RE: GEARS
Thank u much for the help and suggestions- i think im decided on 3:73s- from what i was told before and now these comments- i also want to leave the door open for a supercharger but i was already planning on a tuner so not so worried about that. Sry to be a n00b and hafta ask but what is a t-lock- thats the think on the wheel right?
Old May 21, 2007 | 11:33 PM
SOHCman's Avatar
SOHCman
Default RE: GEARS
ORIGINAL: MlissaG
Yup,
It is a limited slip differential.
The right wheel starts to slip, the left wheel gets power.
MUCH better than the stock one-leg...
You don't get stuck in mud as often, traction in wet weather is 100% better.
There's a bunch of posts out there, including mine, on the details.
It is HIGHLY recommended if you change your gears (won't cost anything extra for the install either).
SOHC
Old May 21, 2007 | 11:58 PM
rmays06's Avatar
rmays06
Default RE: GEARS
I got 3.73's and at hiway speed I am gettin 2750 rpms at 80MPH. Good luck and do the 3.73 for sure.
Old May 22, 2007 | 12:07 AM
NickSezz's Avatar
NickSezz
Default RE: GEARS
ORIGINAL: rmays06
I got 3.73's and at hiway speed I am gettin 27500 rpms at 80MPH. Good luck and do the 3.73 for sure.
Woh...I didn't know our engines could rev that high!!
SOHCman's Avatar
SOHCman
Default RE: GEARS
ORIGINAL: rmays06
27500 RPMS?
What the heck are you running a TURBINE?
SOHC
PS: 2,750 RPMs for me is 90...
Old May 22, 2007 | 01:10 AM
mustangman02232's Avatar
mustangman02232
Default RE: GEARS
the 4.10 with a blower thing is personal choice, i actually liked em on the dealer car i drove but then again that was a 25 minute drive, deff needed something better then stock rubber/suspention
also, if your supercharging, IMO, i would skip over the ford racing tlok and get something stronger like a detroit true trac LSD
Old May 22, 2007 | 02:30 AM
rmays06's Avatar
rmays06
Default RE: GEARS
I'm running a 25 3/4 tire/wheel set up so I'm at about 3.96 gear ratio so I'm happy with the 2750 (the 27500 was a type O....lol)
If I was at a true 27 1/2 tire it would be a 3.73 and then RPMS come down and so does the $$$ spent at the gas pump....
@mustangman THANKS man! But there are plenty automatic S/C'd people having great luck with the (in you oppinion) terrible 7.5 t-lok, The stick is a slightly different story. Not everyone has bad luck and the LSD or true trac and auburn aren't bullet proof either....
Old May 22, 2007 | 06:17 PM
05MustangSally's Avatar
05MustangSally
Default RE: GEARS
ORIGINAL: mustangman02232
I was planning on going with the 3.73s but also with a T-Lock...but I am waiting to buy a Detroit also instead of the Ford
Thunderball
15
Nov 22, 2015 11:49 PM
Bokeo
Oct 10, 2015 08:28 PM
KingRando
Oct 2, 2015 08:06 AM
uedlose
The Racers Bench
Oct 1, 2015 08:31 PM
junior04
Sep 28, 2015 10:53 AM
