3.73's or 4.10's
RE: 3.73's or 4.10's
well it will ruin your highway MPG because it will cause your car to run higher rpm's. But for the exact amount of loss i dont know. My question is what is better for the manual mustang 3.73 or 4.10's.
In addition to considering gear ratio, you need to factor in rear tire diameter. The stock 17" Pirellis are roughly 27" in diameter, but if you are gonna run a shorter 275/40R17 tire like the Mickey Thomspson ET Street drag radial, its dia is 25.7". So that will make your gearing shorter and effectively increase the numeric value of your gear ratio.
Conversely, a taller 28" dia. tire like these...
... will increase your gearing to aratio with a lower numeric value. I like the look of the taller tire, and it's fine cuzI have 4.10's in my 4.0L/5spd coupe.
You also need to consider your driving habits and overall plan for modding your car. If you wanna go forced induction, then 3.73's might be a better choice.
