Brakes
Old Jun 26, 2007 | 07:16 PM
v6 muscle's Avatar
v6 muscle
Default Brakes
Has anyone upgraded their brakes? I was looking for a Wilwood, Baer,Brembo, etc. kit but noone makes one from what I've seen. Any ideas?
Old Jun 26, 2007 | 07:41 PM
157dB's Avatar
157dB
Cut & Paste Expert
Default RE: Brakes
Steeda
MustangsUnlimited
Moss Mustang
They all sell Brembo, WillWood etc.
Get some GT takeoff rotors
and some GT takeoff brackets and
swap them out for the GT brakes
in front. Lots cheaper.
Old Jun 26, 2007 | 07:42 PM
rmays06's Avatar
rmays06
Default RE: Brakes
You can use any of those if they make an S197 kit you just have to upgrade the GT kit and buy the clips from Ford about $40 each to put the bigger rotor on your car. SSBC makes a kit as well.
You can do great work with the brakes by reading this thread as well: https://mustangforums.com/m_2547493/...tm.htm#2547493Make sure you read the whole section crazy al spits some great info and there is another forum on the web C O L L E C T I V Ethat has a sticky about breaks and where to buy the parts.
Old Jun 26, 2007 | 08:51 PM
mdlesk's Avatar
mdlesk
Default RE: Brakes
Checkout the Shelby section on Hillbank Motorsports or just give them a call and ask for Jason. He'll get you all setup.
Old Jun 26, 2007 | 09:18 PM
cvz_finezt's Avatar
cvz_finezt
Default RE: Brakes
the suspension and brakes on the cars are pretty much identical, save for a few parts. but the suspension and brake kits will work on our cars too.
Old Jun 26, 2007 | 09:25 PM
8cd03gro's Avatar
8cd03gro
Default RE: Brakes
dont we have the same rear brakes as the gt? Just get the gt front brakes...the fronts do the majority of the work, and the gt's weigh almost 300 lbs more than we do, so im sure there is a pretty large increase in stopping power from those things.
Old Jun 26, 2007 | 09:31 PM
cvz_finezt's Avatar
cvz_finezt
Default RE: Brakes
the diameter of the rear brakes are the same but the w... wighth... the DAMN WITH. is just a bit bigger on teh Gts. shyt i cant spell today!!
Old Jun 26, 2007 | 09:45 PM
rygenstormlocke's Avatar
rygenstormlocke
Default RE: Brakes
I bought a set of Hawk pads from Powerhouse last week, should get them this week and will do a write up of the difference. Buckman linked me to CrazyAl's post and a bunch of other information. That combined with his calls to various performance shops, and my calls to shops as well. The most I will ever do is pads and perhaps larger front rotors. I registered for autox, if I get around to going I will upgrade my lines to ss lines as that is where they will be stressed enough to make a difference.
Old Jun 26, 2007 | 11:03 PM
GrayPony's Avatar
GrayPony
Default RE: Brakes
ORIGINAL: cvz_finezt
The GT front brake rotors are larger in diameter than the V6. Calipers are the same. Stock V6wheels will not work with GT front calipers and rotors.
Old Jun 26, 2007 | 11:12 PM
cvz_finezt's Avatar
cvz_finezt
Default RE: Brakes
i was comparing back brakes to back brakes
b8checker
Oct 8, 2015 12:55 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
guitarman376
Sep 30, 2015 05:54 PM
Sep 25, 2015 06:42 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
