Tri Bar Emblem help!!
Anyone know if this goes on using 3M tape? Is there a better site where I can get these emblems
http://fordemblem.com/details.php?t=...g&i=110605
RE: Tri Bar Emblem help!!
You can find them on ebay and thruMF vendors... the going price is usually $28 to $35. They come with a locating tab and3M adhesive.The tab can be snipped off for use without drilling the locator hole in the fender.
no tape needed. they already come with adhesive. all you gotta do is clip off the plastic pins on the back and file the nubs down (pretty easy). i got mine from http://www.partscheap.com. i'll be purchasing some tri-bar pony spinners from them also. good site for genuine ford parts at cheaper prices.
i looked at my friends v6 with the pony package. but i also am not a fan of the new emblems. a little too big so i ordered the tri bars that came on the new edge v6's and i love em. but probably the best is go to ur local dealership and take some measurements. if not place it where u like it, and u think is most centered and then make sure its the exact same on the other side.
i followed these measurements that i got from a post when i first put mine on:
" Here are the measurements in case you don't want to just eyeball it:
3 1/2" from fender edge at door to pony's tail
4 3/4" from fender crease above pony to top of tri-bar
As for getting those plastic tabs off, I just used pliers to break them and then filed the rest down. I also scratched off the included adhesive so I could use 3M double-sided tape, but that was probably unnecessary. Be sure to clean the fenders before you apply: dishwashing liquid + water solution is good to get rid of wax and grease, followed by a final wipe with isopropyl alcohol. "
Here's another reference:
https://mustangforums.com/upfiles/29...5AE93479CD.jpg
the location of my emblems look right on with the factory location. good luck.
Here is the link to the how to thread
https://mustangforums.com/m_968605/tm.htm
just scrol down and you will see a little thumbnail with the deminsions.
