X-Charger Discussion Thread
Dave and Patty retired and Xplorer Xpress is now closed.
You need an SCT tuner - the dyno is used to determine the final tune, and a good tuner should be able to give you a base tune to get the car to the shop. Not sure what is available to you in Brazil (my wife grew up in Sao Paulo, but she wouldn't be any help finding a shop now since she came here in 1967 and hasn't been back, plus all of her friends were also ex-pats or from Canada and European countries).
You will need someone who can do a tune for whatever brand tuner you buy (SCT is the most popular) and they write the tune and you load it to your tuner, plug it in to your car, and update. If you have a dyno shop near you they can tune on the dyno, but they still need your handheld tuner to work with.
Well, I found a dyno shop which can try to make a custom tune for me. But it is 2000km away from me...so as I can’t start the engine after installing x-charger, I will need to order a tow truck, that will cost more than the price of x-charger I bought. So I think unfortunately i will not install the blower...
https://automafiaracing.com/collecti...fia-email-tune
I know this thread dates back a few years, but hoping someone takes a look and is able to respond!
My brother gave me his old 2005 Ford Mustang V6 with the X-Charger installed. Unfortunately, it's been sitting on his driveway for years. I'm trying to fix it up and get the car back in running condition, but I need to pass an emissions test first (I live in GA). When I plug in my OBDII, it says my Catalyst, O2 sensor heater, EGR system and O2 sensor are "not ready". After logging over 800 miles trying to complete a drive cycle, I came across this thread and other threads in various forums detailing how it could be a tuning issue.
My question is does anyone know of anyone who works on X-Charger tunes now? It looks like Explorer Express is no longer in business. I don't know who to reach out to or who can help with this.
Was it from a state that didn’t require inspections or smog?
Sitting in a driveway for years could have introduced wiring problems, including from any critters making a home of it.
No idea where you are in Georgia but it looks like there are a lot of dyno tuners in the greater Atlanta area.
So the car was running fine before he quit driving it. He actually got the X-Charger installed directly from the guys who made it (Explorer Express). But you know, life happens. He needed a more family friendly car. So his Mustang turned into a weekend car, which turned into just sitting outside all day..
Our county does require annual emission inspections. But by the time his emission renewal date came around, he wasn't using the car anymore, so he didn't bother taking it in. Had he taken the car in for emissions test at that time, he would have likely run into the same problem I'm currently having right now probably.
Car runs fine otherwise. I fixed it up, replaced all fluids, flushed brakes, flushed coolant, new tires, etc. The car runs smooth today. I just can't pass an emissions test. If I can't pass emissions, I can't register the car. If I can't register the car, well then I can't "legally" drive it around.
Its a long shot, but if you have a relative 65 or older you can transfer the title with them listed first on the title and get a Senior Exemption from Georgia. It might buy you time to legally drive it somewhere to get a proper emissions tune and then you could take them off the title. But I’d expect someone might hesitate to do this because of liability issues.
Mine was originally the California CARB model and I had to pass emissions once in CA before moving out of state, I had a challenge with the emissions tune from Explorer Express (they were still around back then) because it kept triggering a check engine light if I ran the tune too long. I ended up have to load the emissions tune right before testing to pass smog.
