air temp performance
On my 06 v6 manual when the air is cooler the car seems to run good but as soon as the air temp gets a little hot the performance seems quite a bit less, not as juiced . Now I know that for the most part this is normal , cool vs warm air, but I was wondering if anyone knows of any other problem that could be contributing to this or is there nothing wrong at all .
This may sound stupid and guys let me have it if it does. But if cold air is what the motor need why not rote a line from the A/C to the CAI to give it cold air? I'm sure if this was not stupid it would have been done. I know that it takes HP to run the A/C compressor but I wonder if the benefit from the cold air would be more.
ORIGINAL: davesyo
For this very reason I got myself an open style grill so i get a maximum airflow under hood. Also I have a C&L CAI and completely isolated from inside to keep the underhood heat away. Also I routed a 4" (heating duct) flex hose from lower grill to where the Air filter sits to give it additional cold fresh air from outside. After the mod, my performance on freeway improved some. I also ran a test of intake temperature with my xcal before and after mod and my freeway intake temperature dropped to few degrees of outside temperature vs. +15/20degrees prior to changes. I probably gained only 4-6hp at hogher speeds but do notice some difference on freeways when climbing hills in 5th gear.
panic
Sep 10, 2015 05:56 PM
Sep 8, 2015 11:50 AM
