For those with a manual
RE: For those with a manual
I used to drive a fire truck that you could shift without using the clutch, but that's the only manual I've ever driven like that - never seen a car that would do it (without embarrassing myself). I didn'tthink the T5 woulddo it.
This T5 is actually better than my lasttwo Mustangsin one respect, because they moved 3rd over to where it should be. Both my 94GT and 86GT had weird spacing between 1st, 3rd and 5th - if I skipped 4th on a downshift, it was possible to go right to 1st (not good).
The only thing I don't like about this *new and improved* T5 is that I tend to miss the shift from 1st to 2nd under max acceleration. This isthe sameproblem that others have reported.
Edit: Maybe it's my imagination, or maybe it's the higher torque of the V8, but my two GT's seemed to be much easier for me to teach someone how to drive a manual tranny. I don't remember anyone ever being impressed with the manual transmissions in Fox or SN95 Mustangs, but I always considered them good for beginners.
I find the shifting pretty notchy as well but I just figured it was what it was and got used to it. I've driven alot of different manual cars over the past couple decades and some are just smoother than others. The car I hadthe hardest time with was a 1987 Porsche 911 Carrera...VERY difficult to find those german gearsbut when you do, it was a fun FAST ride!
My biggest issue on this car wastrying to get into reverse. It seems on my car that if the shift is fighting going into R when I have the clutch completely depressed,then I let the clutch out just a little bit and the gear pops right into R. I don't know why that is because I'm not car-smart but at least I figured out the 'trick' to it so I don't have problems with it anymore.
ORIGINAL: ArcticFrog
I find the shifting pretty notchy as well but I just figured it was what it was and got used to it. I've driven alot of different manual cars over the past couple decades and some are just smoother than others. The car I hadthe hardest time with was a 1987 Porsche Carrera...VERY difficult to find those german gearsbut when you do, it was a fun FAST ride!
I installed the CHE K member brace and torque limiters on my car and the shifting improved a bunch, I would recommend it to anyone with a manual. I also have the hurst which I really like as far as throw distance.
ORIGINAL: sleeper07
it is true, you CAN shift a manual without using the clutch; however, you have to be really good at doing 'power shifts' and its really easy to screw up. you have to make your shift at the exact rpm required for whatever gear you're wanting to shift into, and that rpm is whatever you believe to be correct based on your experience with the car. but, assuming that you are correct in determining the exact time to make the shift, you must also be able to rip the shifter into the desired gear as fast and as hard as possible. any slight hesitation or lag or weakness in your shift will result in a lot of painful gear grinding. i personally dont recomend 'power shifting' because knowing that exact rpm range for each gear isnt usually consistant with every car due to driving conditions and situations and it may fluctuate accordingly. also, like i said before, any hesitation in the shift itself and you're screwed lol. not to mention that shifting normally is already clunky enough for us. genreally speaking, shifting without a clutch is something that a lot of truckers/semis do, but, if you can do it, it may save you some time in 0 to ? time. im curious to know if anyone on here has ever tried this in their car and if it is how they normally drive
ORIGINAL: sleeper07
yeh this really bothers me...sometimes the shifting is really nice though, other times its crappy beyond belief. Going into first and reverse (no synchros) is even more of a hell. one time i thought it was in reverse and I started going but then as i released the clutch there was a lot of grinding ick. Now also, my friend in his car, downshifts into first? wtf? If i even dared doing that on this car a....it would not go in, it never goes in when im moving, and b. it would just be really odd Do any of you guys downshift to 1?
ORIGINAL: angera
I couldn't find this anywhere else...
I am not a car person. I do not know jack about cars. So I am asking this as someone completely and utterly ignorant of cars.
What the hell is up with the manual shifter on the v6? Ok, I've owned two other stick shifts. One, a '94 tercel which shifted smoothly but was a bit like pulling the crank at the slots (long wayto each gear.) My second was an '04 civic. Smooth, bee boo bop short distance to the next gear. Mustang? The first few days I had to search around for the gears. Ok, normal getting used to a new car. But damn, the thing is notchy, as in I have to push through one or two notches to get it in...and I have to really push it into position. Yes, the cluth is in when I shift. Will the thing loosen up over time or s this normal or do I have a lemon?
