PLEASE HELP WITH V6 GRILLE UPGRADE!!
RE: PLEASE HELP WITH V6 GRILLE UPGRADE!!
yea im putting the gt grille on my V6 and as far as i could tell when i was researching info about it the rectangular box just pops off. there shouldnt be anything else that would have to be taken off.
Yea i got most of it working right, i need to get them wired to the parking lights.. having trouble figuring out what wires i need to splice into... cant find the correct wiring diagram anywhere anyone know what they are?
ORIGINAL: Caladius
http://img505.imageshack.us/my.php?image=img2985si1.jpg
ORIGINAL: sonic245
If you just need access to that switch, it just pops off. No need to take anything else off the dash. Just get a small flathead screwdriver, start on the bottom of the black panel and gentlt pry out the bottom. Its real easy, once the bottom pops out enough, you can basically just pull it the rest of the way out. Be careful not to scratch it though. Good luck!
end of the dash assembly. Then reach in and push it out from the back.
Be careful of flying clips that disappear into never never land. I tried the
screwdriver approach and have dings in my dash because of it. Push
it out from the rear thru the access panel. You will be glad you did.
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
