jba headers
Old Oct 17, 2007 | 06:37 PM
Trmachuno's Avatar
Trmachuno
Default RE: jba headers
ORIGINAL: Torch_Vert
ORIGINAL: alsoknownazg
what exactly do headers do?
They smooth out exhaust flow as it exits the engine. The stock exhaust manifolds they replace aren't horrible, but are cast iron, with rough finishing inside and some restrictions.
Chrome will NOT do the same as ceramic in keeping underhood temps down and internal exhaust temps up. Ceramic acts as an insulator on the pipes, chrome is just applying another metal (shinier) over the existing metal, so it doesn't effect heat characteristics much. Chrome also tends to discolor rapidlyunder high heat, taking on a bluish or brownish hue.
I'm running stainless JBA's that I had custom ceramic coated by Jet-Hot (had to do it that way because I wanted to add EGT sensor bungs and needed those welded on before the ceramic was applied)
imho, the ceramic is well worth the extra $$$. It really does a great job keeping things under the hood cooler, and looks much better than the raw stainless.
And have u dyno'd ur x? If so w/what mods? I want to know b/c I'm gonna get one by the summer and would like to know 1st hand #'s. Thanx Ahead!
Old Oct 17, 2007 | 08:10 PM
Torch_Vert's Avatar
Torch_Vert
ORIGINAL: SteelStang05
I don't have a recent dyno run. Probably will go in a few weeks. Will post results when I do.
Old Oct 17, 2007 | 08:13 PM
Trmachuno's Avatar
Trmachuno
Cool! Thanks for the help! I will love to see those numbers when they come and good luck on the dyno tune!
Old Oct 17, 2007 | 09:52 PM
Dennis074.0's Avatar
Dennis074.0
hey steelstang, how much did you pay to have the H-Pipe and shorty headers installed? and how long did it take them to install?
Old Oct 18, 2007 | 05:43 AM
Trmachuno's Avatar
Trmachuno
I am not exactly sure for the h-pipe and shorty headers, but when they installed them with my duals and overaxle pipes it cost $450 for the install. And they had to switch the cats on my y-pipe with the cats on the h-pipe. Install time was about 4-5hrs for everything. Hope this helps you out. If u were just getting an h-pipe and shorty headers installed, it willbe around 2-2.5hrs and cost you $180-$250.
Old Oct 18, 2007 | 03:25 PM
Dennis074.0
where did you have the setup installed?
Old Oct 18, 2007 | 03:49 PM
Sancho805's Avatar
Sancho805
how bout shorties alone? is that something i can do myself or should i let a shop do it?
Old Oct 18, 2007 | 04:02 PM
Dennis074.0
I'd let a shop do it, theres alot of taking stuff off, then putting things back on.
Old Oct 18, 2007 | 04:37 PM
Sancho805's Avatar
Sancho805
ORIGINAL: Dennis074.0
well i've done it to a 1950 chevy fleetline but i guess today's cars are more complicated....what would a header install cost alone?
Old Oct 18, 2007 | 05:28 PM
Trmachuno's Avatar
Trmachuno
Dennis: Set-up installed at a performance shop in Massapequa
Sancho: You probably could install them if you have some automotive experience, I've heard of some people installing shorty headers in their driveway in 1-2hrs.
