Another exhaust question
I've been reading alot on here about duals. I'd like to get them on my 05. I went to a local muffler shop today and they talked about cutting into the pipethat goes to the single exhaust. This cut would be about 2 feet in front of the axle and they would add a pipethat would go up and over the axle to the muffler. I know this isn't true duals. I purchased an extended warranty and don't want to void this by making it true duals. At least this guy I talked to said it would void the warranty. Would I experience any performance problems with this setup? Would this setup have a major impact on the sound? The sound is what I'm really seeking. The guy at the muffler shop said it wouldn't but I wanted to get other opinions. Thanks.
RE: Another exhaust question
so basically you'll have two y-pipes to make your dual exhaust. jba sells this optional kit pre-fabricated. from what i've read, the best sound comes from the dual exhaust h-pipe setup which is true dual with a connecting cross pipe. i have the h-pipe setup and love it. if i were you, i would be a little more realistic with the warranty issue. if your going to mod your car, go with the best option for your car and what YOU want.
Ford also sells a V6 Dual conversion kit with a warranty, but I think it's only valid if Ford installs it.
I got Pypes Performance X-pipe with GT takeoff mufflers. The X pipe is the set up Ford uses.
Here's a link;
http://www.fordracingparts.com/parts...tKeyField=9910
Here's a link;
I agree with Sancho. True duals and an H.
If my stealership wanted to, they could probably void myEXHAUST warranty.
Pipe, cats, hangers, sensors etc......
I can take the tune off when I go to the stealer, but not the duals.
yeah, unless the muff shop intentially sabotages your exhaust or simply doesnt know what the f**k they are doing, then exhaust would not be something i would worry about with my warranty. i've taken my stang in twice already for rattling and computer issues. my duals and intake were installed before taking it in. haven't had any tech or service rep mention either mod at all. as i said earlier, go with the best option that is best for your car, not neccessarily what is best for your warranty, although you wouldn't want to do anything extreme that would void it since you already paid for the extension. if done right, your car will run smoother, stronger and with less stress as opposed to that terrible restrictive stock exhaust.
Thanks for the comments. You know, as I think about it I had a Ford F150 several years ago. During the factory warrant period I had duals installed. My transmission went out several months after the duals were installed and there were no questions by Ford. The covered the transmission w/o blinking.
ORIGINAL: bterry29
yeah, the WHOLE warranty isnted void, just areas that could be affected by your modifications. and besides, your exhaust shouldn't void anything of real significance. so, get those duals on there!!! haha
ORIGINAL: Sarge_13
Getting duals will only void your exhaust warranty. I seriously doubt you'd have any problems which required them to work on that anyway.
I didn't because at the time it wasn't offered by Ford. Like so many has expressed, it's rare that there are problems due to the exhaust.
