Ford EASYCARE Extended Warranty
Hi folks,
Sent my baby to the dealer to check out a few things before my extended warranty runs out.
1. Front-end clunk since day one (TSB)
2. Passenger compartment water leak (TSB)
3. Automatic shifter not engaging D (4th) when upshifting from 3rd
4. Radio - CD changer has trouble ejecting / loading CD
Well, all of them were verified by a Ford tech.
Easycare will only cover the friggin' radio.
Any ideas how to get these repairs done under warranty?
Thanks
SOHC
PS: Reposted this from another board since I'd like your experiences with Easycare.
Thanks
SOHC
RE: Ford EASYCARE Extended Warranty
so what are the details of your warranty? Usually electronics, such as the radio, are only covered under the most comprehensive plans meaning that if it is covered then so is everything else. I would pull out your warranty papers and figure out what is and isn't covered. How many miles is your warranty to coverage for? You have an 06 right?
ORIGINAL: laserred02
Covered till 75,000 miles (about 70,000 now).
Yup it is a 2006
I drive a lot...
SOHC
What level coverage do you have - PowertainCare, BaseCare, ExtraCare, or PremiumCare? And what is EasyCare? Ford calls their warranty ESP - Extended Service Plan (https://www.genuineservice.com/genui...new_esp_browse).Did you buy yours from the dealer?
ORIGINAL: richmod
It what I got from the dealer with my new car.
I have the maximum coverage for the plan.
ORIGINAL: Sancho805
so was the extended warranty worth it?
Have had other work done before, plus a new set of tires at 42,600 miles...
I aint just giving up just yet.
ORIGINAL: Sancho805
ORIGINAL: SOHCman
I have the max coverage for the plan.
Yup it is a 2006
I drive a lot...
SOHC
Yup it is a 2006
I drive a lot...
SOHC
Most plan state they will not fix: squeaks, rattles or water leaks. However, since there is a TSB out on the front-end clunk, and the water leak they should fix it since it is a defect with the car, not parts worn over time.
Best of luck!
Best of luck!
