Winter Storage Question
Old Nov 15, 2007 | 10:23 AM
Mystang07's Avatar
Mystang07
Default Winter Storage Question
Hey all! Well the cold North wind is a blowin', and it's time to put the pony up for the Winter. But first, a stupid noob question:
My in-laws' garage is not heated, so should I remove the battery and store it inside the house? Will this have any negative effects on my 93 octane tune when I put it nack next Spring?
Other than adding Sta-Bil (already done this morning) to the full tank, is there anything else to do? I just had the oil changed about 1000 miles ago.
Thanks!
Scott
Old Nov 15, 2007 | 11:03 AM
banka87's Avatar
banka87
Default RE: Winter Storage Question
You could pull the battery out, it won't re-set your tune. Put your car on jack stands.
Old Nov 15, 2007 | 11:14 AM
theresa's Avatar
theresa
Banka. Why do you put it up on jack stands? For the tires? If so, can you park it on
carpet instead?
Old Nov 15, 2007 | 11:36 AM
Mystang07's Avatar
Mystang07
ORIGINAL: banka87
Wouldn't putting the car up on stands fubar the springs?
Peace!
Scott
Old Nov 15, 2007 | 11:38 AM
157dB's Avatar
157dB
Cut & Paste Expert
Run the engine for a while after adding the stabil
so it gets into the whole fuel system and not just
the fuel in the tank.
Leave the doors open a bit to save the rubber
weatherstriping around the glass.
Put some desicant inside to absorb any moisture.
+1 on the battery disconnect.
Trickle charger for the battery?
Old Nov 15, 2007 | 12:03 PM
Mystang07's Avatar
Mystang07
ORIGINAL: 157db
Yep, got that part covered.
Peace!
Scott
Old Nov 15, 2007 | 03:40 PM
Idaho's Avatar
Idaho
Banka. Why do you put it up on jack stands? For the tires? If so, can you park it on carpet instead?
The purpose of placing the car on stands is to unload the suspension so that it won't sag over time.
Only if you you lift the car completely off the ground. WhatI did was go to the auto salvage yard and buy four scissor jacks to just lift the body so the suspension is in a neutral position . I also used rubber mats that 1/2" thick under each tire.
Scott, if you used synthetic oil the 1000 miles won't be an issue but if you used standard oil or a blend I would recommend changing it out with a synthetic for the winter. Instead of pulling the battery I would recommend installing a battery minder; it has been my experience that if you start the car once a month and let it get to normal running temperature you don't end up with loud lifter noise when you take it out of storage.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
baddog671
Jul 26, 2016 01:20 PM
AMAlexLazarus
AmericanMuscle.com
Oct 2, 2015 08:06 AM
UrS4
Sep 30, 2015 10:13 AM
treesloth
Sep 28, 2015 07:03 AM
