JBA Header Install Help
Old Nov 16, 2007 | 01:53 AM
blackstang14's Avatar
blackstang14
Default JBA Header Install Help
Hey guys,
I am in the middle of the header install and while I consider myself pretty handy, my experience with cars is pretty minimal. But I since I have been having as much fun as you guys modding, I wanted to tackle this myself. So after removing both stock headers (with some difficutlies as the torx heads broke offof 3 bolts, which required a laborous removal with vice grips and elbow grease), I have the new headers in place but I am having problems getting the JBA bolts to thread. In particular the bottom bolt entering cylinders #2 and #4mostly because I can not seem to get a great angle toget at them. Before I start removing things to make more room, I wanted to see if anybody else has any advice.
Thanks for your help in advance
Old Nov 16, 2007 | 02:27 AM
Sancho805's Avatar
Sancho805
Default RE: JBA Header Install Help
check this recent thread. you might find some helpful info for your install.
https://mustangforums.com/m_4176240/tm.htm
Old Nov 16, 2007 | 04:47 PM
jwilhelm's Avatar
jwilhelm
The JBA header install is definitely an intense endeavor. I'm going out right now but will get back with you tomorrow morning on the subject. Just went through a total install myself and I'll share my experience with you. Jack
[IMG]local://upfiles/63501/5B17357004B242DE95BAA2DC6F950AAD.jpg[/IMG]
Old Nov 17, 2007 | 01:58 AM
blackstang14
Thanks for the help. I had a productive hour after work tonight and actually installed the passenger side without too much swearing
I decided to declare a victory and I will finish up the drivers side which is half finished tomorrow. After reading a few other threads, I wish I had left the torx factory bolts in place to begin with and just slid the new headers over the bolts. But heh, I think it will be well worth the effort once it finished--especially doing it myself.
James
SSG Steggy
3.7L V6 Technical Discussions
Nov 5, 2015 03:09 PM
Luke9222
Oct 22, 2015 11:55 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
Luke9222
Sep 4, 2015 06:46 AM
