Header Question
Old Nov 30, 2007 | 12:54 AM
PFC_Kurtz_John's Avatar
PFC_Kurtz_John
Default Header Question
Kinda noob question. What is the differance from Shorty Headers and the long ones other than the obvious length.
Old Nov 30, 2007 | 08:37 AM
28HopUp's Avatar
28HopUp
MF Administrator
Default RE: Header Question
Shortie headers retain the stock (or aftermarket) catalytic converters. Longtube headers are indeed longer, and they eliminate the cats.
You will also sometimes see the term "off-road pipes", which just means that the pipes replace the section where the cats were located.
Old Nov 30, 2007 | 11:27 AM
Sancho805's Avatar
Sancho805
definitely not carb legal, hence the name "off-road pipes".
Old Nov 30, 2007 | 11:43 AM
Jsierzega's Avatar
Jsierzega
will you get enough back pressure without the cats if your car is n/a??
Old Nov 30, 2007 | 12:02 PM
PFC_Kurtz_John
ORIGINAL: Sancho805
^Good to know^
Thanks for the posts I was just curious about it. Thanks again.
Old Nov 30, 2007 | 12:08 PM
Sancho805's Avatar
Sancho805
ORIGINAL: Jsierzega
backpressure is not what you need. you need more exhaust volume to fully benefit from LT headers (F/I for example). your car might feel more sluggish if you stay N/A with long tubes because your exhaust volocity will be slower with the less restricted setup. not sure how much long tubes really affect a N/A car but this is the theory nonetheless.
here's an experiment: using a garden hose with no attachment, turn on your water to a set amount and see how far the water goes. now pinch/bend the hose near the opening little by little and see if the water travels farther. now pinch it a lot more and see how far it goes again. about halfway pinched should yield the farthest distance (highest velocity). it all comes down to how much exhaust you got coming out in the first place, then how fast you can make it travel. i understand its never as simple with engines but its still a BASIC analogy.
Old Nov 30, 2007 | 02:35 PM
Jsierzega's Avatar
Jsierzega
i get what your saying
Old Nov 30, 2007 | 03:59 PM
basketballord's Avatar
basketballord
ah backpressure...
Old Nov 30, 2007 | 04:20 PM
Sancho805's Avatar
Sancho805
ORIGINAL: basketballord
ah backpressure...
hahaha.....yeah really. i'll stop.
Luke9222
Oct 22, 2015 11:55 PM
firecoyote
Sep 27, 2015 02:37 PM
Daddys Girls GTs
Sep 14, 2015 08:46 PM
BrantleyS550
Sep 14, 2015 04:18 PM
raleigh05GTO
Sep 4, 2015 07:09 AM
