Valve float vs Tranny Failure
Old Dec 17, 2007 | 06:58 PM
blackstang14's Avatar
blackstang14
Default Valve float vs Tranny Failure
Looking for F/I soon but I have a question. Which is likely to fail first tranny vs internals and at what power levels. Is it based on RWHP or lbs of boost (i.e. turbo/supercharger)???
Thanks
James
Old Dec 17, 2007 | 07:21 PM
chrisc's Avatar
chrisc
Default RE: Valve float vs Tranny Failure
The auto tranny can do 400rwhp+ and the manual tranny can do something around 370rwhp
Old Dec 17, 2007 | 08:57 PM
fazm's Avatar
fazm
the trans is actually based on torque, not hp.
ive blown 2 stock transmissions, a built 7.5 rear, and a stock 8.8 rear and my engine is fine....
Old Dec 17, 2007 | 09:24 PM
blackstang14
Thanks guys,
So would you say around 350-370 torque would be the gray area?
Old Dec 18, 2007 | 10:24 AM
28HopUp's Avatar
28HopUp
MF Administrator
ORIGINAL: blackstang14
Thanks guys,
I'm not sure you should fixate on final HP numbers. When going FI, the amount of boost (and your tune) will determine engine longevity. I remember reading that 11psi was the agreed upon top level of boost to run safely. A turbo at 11psi will generate more HP and torque than a supercharger at 11psi.
Old Dec 18, 2007 | 12:34 PM
rmays06's Avatar
rmays06
+1 scrmin had stock rear end and a fast car 12.8's with no engine, trans or rearend problems.
Droptop6 had the same set up and floated 2 valves and did his rear end wrong.
ORIGINAL: 28HopUp
Thanks guys,
Old Dec 18, 2007 | 02:03 PM
lrgnation's Avatar
lrgnation
ORIGINAL: 28HopUp
Thanks guys,
Depends on the tuning as well, if you run lean for like a few seconds at 11psi on a stock motor there is going to be some engine longevity problems..
Old Dec 18, 2007 | 04:31 PM
blackstang14
I was referring to the Transmission withregards tofinal numbers/torque. I agree that the engine longitivity would be combination of boost and tune. Am I right to assume that our manual transmissions would be more likely to go before our stock motors?
GimpyHSHS
19
Dec 19, 2023 01:12 PM
mrtrodonet
Sep 19, 2020 03:12 PM
svfetter
Oct 5, 2015 11:39 AM
treesloth
Sep 28, 2015 07:03 AM
2poor4u2
Sep 26, 2015 11:08 AM
