Vortech Supercharger
RE: Vortech Supercharger
ORIGINAL: 05nightrider
what about these steel/metal head gaskets that will allow for severe increase in compression ratios?
also, with cams and supercharger, what kind of power could you see? 400rwhp? 450rwhp? what else can be done to make even more?
new injectors?
rods?
pistons?
arent our heads already aluminum? so why replace them?
new injectors?
rods?
pistons?
With heads and cams, you are looking at numbers between 380-450rwhp depending on boost and what kind of heads and cams you do. New injectors do not add more power, they just allow you to reach the power you should be getting. If you dont have sufficient injectors, bad things could happen. Nobody has tried upgrading the bottom of the engine yet with a supercharger, with good parts and a built drivetrain, you can be looking at a ton of power. Our heads are iron as I remember. However, it is not the material of the heads that matter when you are looking for power, it is the work done to them. Aftermarket heads are usually ported and polished (along with a few other things that are too technical for me to remember off the top of my head) and that makes the power.
ORIGINAL: scrming
are you talking HP or RWHP?
ORIGINAL: taz9124
I will be installing my Vortech supercharger with aftercooler soon... I should be looking at 330 HP. I'll have to wait and see once its all said and done
ORIGINAL: taz9124
The manual states 330 HP with aftercooler at 10 psi boost
ORIGINAL: scrming
ORIGINAL: taz9124
so which is better for a street/ occasional strip car? intercooler or aftercooler? whats the difference?
Aftercooler and intercoolers are not the same thing. Most cars do not use intercoolers anymore. Aftercoolers are placed after the compressor, while intercoolers are placed before the intercooler. I have never seen a car that actually uses an intercooler.
However, for some reason, people have started to refer to air-air coolers as intercoolers and air-water coolers are aftercoolers.
ORIGINAL: scrming
330 HP is based on the "canned" Vortech tune... i would invest in a good dyno tune for optimal results... should be able to get 300+ RWHP!
ORIGINAL: taz9124
ORIGINAL: scrming
ORIGINAL: taz9124
ORIGINAL: chrisc
And intercooler is placed BETWEEN two compressors (hence "inter") not before...
So in fact aftercooler is technically the correct term, whether it's air-to-air or water-to-air... unless of course you have a dual compressor setup which is very very unlikely (and I don't mean twin turbos, which are in parrallel)... but most every one uses the term intercooler except for Vortech...
you are correct John, learn a new thing every day.
wikipeda:
"aircraft engines were built with charge air coolers that were installed between multiple stages of supercharging, thus the designation of inter. Modern automobile designs are technically designated aftercoolers because of their placement at the end of supercharging chain"
wikipeda:
