Cold Air Intake Questions
#21
RE: Cold Air Intake Questions
ORIGINAL: GidyupGo
You all realize that the Shelby 350 uses the stock tube as well as Ford racing.
the stock tube flows decently but it has too much bend in it to be maximized
Cabbage If it didn't ask you what tube you wanted it probably just comes with the canned tunes preinstalled on the xcal2. C&L is one of the cai options on it
#22
A couple newthoughts crossed my mind today.
1. Should I upgrade my exahust before I get a new CAI or is stock okay for awhile?
2. How come the FRPPpower pack only advertises 10hp gain when all the CAI say atleast 12-15 gain? The ford pack comes with exhaust too so shouldn't that be getting better gains than just the CAI alone?
Also I got a quote on this pack from a local dealer for $925 is that good, what have you guys that have them been paying?
Thanks.
Thanks.
#23
ORIGINAL: Cabbage
Thanks.
Thanks.
2: Why does a steak at Ruths Chris cost 3x as much as a local restaurant for the same grade and cut of steak?
First, unless you are going forced induction, the rubber air path is fine, the sixers aren't sucking so much air that the rubber causes significant loss. You need to replace the air filter box, that's the big restricter. Then, since you did that, you need a tune. If you were an old timer you would understand that if you put mroe air down your carb without increasing fuel a little you would run lean which is not good. That's one of the things the tuner does but you don't need to spend hours like we used to, it takes about 8 minutes.
If you want to gain some instant HP and improve mpg on the cheap, replace your axle back exhaust with a GT takeoff. The other brands, flowmasters, mrt, pypes etc etc don't really give you any better performance it's just sound preference. Depending on who you listen to, this simple mod, which takes 30 minutes and you don't need to jack up the car, gives you anywhere from 7-10 more Wheel horsepower. Then, the CAI and tune, if you do 91 octane should give you anywhere from 12-15 more WHP, maybe a little more. You can doo all of that for under $600 and it should take you no more than 1 hour total. As for putting on duals, that is more for style than performance. Since you have a sixer, crawl under the car and look at the size of that exhaust pipe; it's quite large. Again, since you aren't supercharging, it is fine. The OEM muffler is very restrictive thus why an axle back is an easy mod that you should do.
I've been in a sixer that was a stick and had the axle back replaced and a CAI and tune. That son of a gun has some torque (that seat of the pants feel) and runs every bit as hard as a friends' classic 302 mustang. I think it runs harder. With the prices of 07 leftovers, I'm thinking of buying a v6 manual if i can find one to throw in the garage and keep. It would make a good college graduation gift for my daughter and I could spend time tinkering before giving it to her.
Oh, all my kids drive manual transmission cars, they're just too much fun.
#25
woah there. exhaust is a whole other issue here. there is a lot of research involved in getting a new axle back as far as sound and drone, be sure to check out the exhaust clips thread:
https://mustangforums.com/m_617216/tm.htm
and check out youtube for clips from just about every axleback out there. i went with the borla axle back, its very pricey but i got a great deal from another forum member, GREAT GREAT sound, a little drone, and it really cleans up the back end from that ugly stock muffler.
as far as tuner brands, i have a diablo, very user friendly and has a lot of CAI support tunes right out of the box. highly recommend it for someone new to modding cars like i am.
#26
ORIGINAL: Devil Wolf
Whatever you choose, the whole "experience" routine or just ***** to the wall, this is a car, not curtains for the living room and get it done, you'll be glad you did
09-01-2015 08:16 PM
Calizic
08-28-2015 01:46 PM
