Top Speed
RE: Top Speed
Technically, as fast as you can get it without blowing the engine. You will run out of snort at a certain point though unless you're going downhill. And if you are planning on going that fast, (on a track of course, cuz people on here don't like to hear about going that fast anywhere else) then you should upgrade your driveshaft. The stock one is heavy, cumbersome, and dangerous at those speeds. One guy's busted on the dyno if I remember correctly.
RE: Top Speed
I don't ever go above 100mph. But with the stock gears, an aluminum driveshaft, and the right rated tires I'm sure that 140mph isn't impossible. Maybe more. I am just not stupid enough to try it. Going that fast on the street/highway is how people get killed and lose control of there car b/c they hit a rock or a little bump. Drive safe!
RE: Top Speed
Someone did that compaison with the GT. Given various gears and trannies, without taking into consideration for friction, rolling risistance and air drag, theoretically it could go 200+ mph. It would be interesting to have someone do that with the Pony.
RE: Top Speed
I don't see the aerodynamic limit of the body being any higher then 150mph...and thats pushing it...andI don't think a V6 will get to that speed...just a guess tho. The front is shaped like a plow.
