will I gain any performance form single aero turbine?
Old 02-28-2008, 10:51 AM
Mustang_guy17
Mustang_guy17's Avatar
Default will I gain any performance form single aero turbine?
I ordered it and it is coming in the mail.. Just wondering what to expect performacne wise?.. I got a cai and tuner already with a 91 oct tune from justin.
Mustang_guy17 is offline
Old 02-28-2008, 12:04 PM
Sancho805
Sancho805's Avatar
Default RE: will I gain any performance form single aero turbine?
you can safely expect at least 8hp gain, assuming the aero turbine is well made. 8hp might be a lot on a 4 banger but it might not be too noticeable in our 4.0's. the biggest difference will be the awesome sound and at WOT. good luck with it dude.
Sancho805 is offline
Old 02-28-2008, 12:12 PM
legendlime05
legendlime05's Avatar
8hp might be a little high, im for sure so dont quote me.
like said above the biggest difference will be in sound
legendlime05 is offline
Old 02-28-2008, 05:09 PM
scrming
scrming's Avatar
I went from a Magnaflow to an Aero-Turbine... I definitely felt a difference with the butt dyno... in fact it was so noticable in the upper RPMs I thought my butt dyno was broke... so i actually took the car over to Alternative Auto and put it on the dyno.. sure enough the dyno showed that I did pick up some HP over the Magnaflow (which we know is better than stock... )
Here's the dyno sheet:
scrming is offline
Old 02-28-2008, 06:29 PM
MadMoose
MadMoose's Avatar
I've got about 800 miles with my aero turbine now, and it does feel a little faster in the higher rpms.
It sounded a little on the high pitched side when i first installed it but has gotten deeper and more agressive sounding. nice rumble below 3k rpm too.
MadMoose is offline
Old 02-28-2008, 06:34 PM
Mustang_guy17
ORIGINAL: scrming
thanks for the info.
Old 02-28-2008, 08:00 PM
Sancho805
Sancho805's Avatar
this is good info for those who doubt the possible exhaust gains. i know not all muffs will be as good but its def possible with a quality exhaust setup.
Old 02-28-2008, 08:06 PM
Fallout
Fallout's Avatar
you will feel the gain, then if you are like me you will feel the need to change axlebacks after about 300-400 miles
Fallout is offline
Old 02-28-2008, 09:07 PM
VictoriaRR
VictoriaRR's Avatar
I felt a bit of an improvement in acceleration on mine... moreso at the high end as far as I can tell. I love the low rumble but once you get past 3k rpms it can be a bit much. No matter what, though, it'll definitely get you attention.
VictoriaRR is offline
Old 02-29-2008, 04:32 AM
hataap
hataap's Avatar
hah, i was waiting for scrming to chime in...i would have had to dig up his dyno sheet if he hadn't. i still am surprised by those gains--very impressive
hataap is offline
Dokilar
15
10-16-2015 08:13 PM
ChampInSD
10-02-2015 04:55 AM
Boostaddict
Lethal Performance
10-01-2015 08:58 AM
Boostaddict
3.7L V6 S550 Tech 2015 - 2017
10-01-2015 08:57 AM
Florida Regional Chapter
09-30-2015 08:04 PM
Quick Reply: will I gain any performance form single aero turbine?
