So, here's my thing and a sign of my limited knowledge of the mechanics of my mustang. I can smoke my "tire"...but not my "tires". Not a huge issue but has been nagging at the back of my brain for a while now....why won't they both spin? And what do I need to do to remedy that? Now I do have plans of buying a 8.8 rear with 3.73's and the flange already installed ( not that I know how to actually do the swap) so anyone with info on how to cure my ocd would be appreciated.
The stock 4.0 V6 has an open differential. You are essentially peg-legged. Get a tlok installed in your 7.5 rear, or upgrade to the 8.8 rear which already comes with it.
Not to my knowledge...but then my knowledge is pretty limited. If I did where would I find its off button?
If you did have Traction Control, then there would be a button on yourcenter console above the radiothat would say "TCS Off," or something like that. If you don't have that button, which I'm assuming you don't, because if you did it'd be pretty easy to spot, then you probably don't have Traction Control either. So I'm guessing that's not the issue...
