Tail Light Question
RE: Tail Light Question
Use the Sylvania LongLife bulbs and replace
them all while you have the darn taillight assembly out.
There is a write up for sequentials that shows removing
and replacing the taillight assembly.
https://mustangforums.com/m_3065383/tm.htm
More help
http://iihs.net/fsm/?dir=391&viewfil...20Assembly.pdf
Beware of scratching the paint with the mounting
studs when you pull the housing out.
Be mighty careful.
Be mighty careful.
Hey Phillip, what you really should do is take out the bad bulbs, then first go to an auto store and buy new replacements, then go to your Ford dealership and buy a new stang to put the new bulbs in. Onward, Jack. []
Bad Idea dont let Auto Parts sotre people help you with your car... most of them are in a hurry and dont want to help you and will probably break something while doing it if you have the time do it yourself
