My new GT front end
#21
RE: My new GT front end
LIVNBIG,
here is the deck i'm going to put in my car. i'm getting the kenwood navigation GPS Navigation system with it. you got any suggestions for aftermarket stereo equipment??? let me know please, i'd like to hear some suggestions.
[IMG]local://upfiles/16139/37741F3543C94E2CABA0A61C0F180DDD.jpg[/IMG]
#22
That looks good Jrod, especially with the GPS! Mine is the pop-out and up type..I want to put a passive EQ in the space below it!! Suggestions, check my sig...I will be going with dual 10"s later in the trunk! But trust me, the Sony 12" I have in there now rocks!!
quote]ORIGINAL: Jrodmaster
LIVNBIG,
[/quote]
LIVNBIG,
[/quote]
#23
here is the wire diagram. here is the deal. if you just want to use the gt switch just hook on to the wire at the switch or by thr smart box right side of car. it is the orange lite green one. if you want the led on the switch to work when you use the switch you will have to install the fog relay and fuse it is under the hood the relay is a micro relay same as the high beam relay also the fuse is a 15 amp f:158 position and the relay goes in the center then just run a jumper from the orange lite green wire to the dark blue /white wire this trips the relay and turns on the switch light.
[IMG]local://upfiles/14019/A317CF9D444C43C682DCD0EE13921DE4.jpg[/IMG]
#25
How did you remove your front bumper?
I tried to remove mine last night but after taking bolts off the top and the screws from the fenderwells, I couldn't figure out what to do next.
I've got a couple fog lights that I am trying to custom fit, but I want them in the 67 Corbra location (where the license plate is), so I am fabricating my own mounting brackets... problem is, when I went to take the bumper off to set everything up, I couldn't figure out how to remove it...
any info would be appreciated...!
#26
I can't tell from your post if you completely removed both the wheel well halves or not! This makes it easier if you do! The rear one comes out first, then the front half! When both wells are out, peek your head inside the wheel well and look at where the bumper cover attaches to the fender. You will see a nut, there is another just like it about 2 inches further down the ridge there...un-bolt and remove both of those! Repeat on the other side!
With all the rest of bolts that you have already taken off, removed, carefully pull the bumper cover down! Do this as evenly as you can doing both sides together if possible! I had my wife help me! It's a tight fit and you don't want to scratch anything, a second pair of hands is a must! It comes off REALLY easy, I was surprised how easy it came off! The turn signals are riveted on the bumper cover and will need to be removed in order to switch them over to your new bumper cover! I have a rivet gun and re-riveted(is that a word) the turn signals back on my new GT bumper..wheeeeeeeeeeeeeeeeeew.....hope that helps...it's easier to do than explain!
ORIGINAL: StupidTodd
