Idling high when in neutral and coming to a stop??
I've been experiencing high idle issues for about 2 weeks now. It occurs when I am slowing down to a red light or stop sign. Once I come to a complete stop, the car is still idling around 1.5 RPM! After a few seconds the idle will go back to normal....It used to do it everyonce in awhile; however now it is occuring all the time. It's a good thing I have a 5 speed and am able to put it in neutral.If I had a manual, I think it would pull me forward and would be hard to stop!
Any ideas on what maybe causing this issue?
Suggestions/ideas?
Thanks!
Suggestions/ideas?
Thanks!
RE: Idling high when in neutral and coming to a stop??
Pretty common. Mine does the same depending on tune. According to my engineering source at Ford, should only happen while coasting in neutral. its intentional as the ECM needs to keep up oxygen sensor temp to keep the emissions within spec. They accomplish this by revving idle up to 2K rpm while coasting in neutral with the clutch out on manuals. It is road speed sensitive, it will throttle down when ECM senses cluth down coasting, or at a stop. I dont know if Auto's have this issue (unless they put it in neutral while coasting?) . The only cure I know of is to get a tune from Justin at VMP that turns off the downstream rear oxy sensors and he can then tune it out. I think Doug does this as well for his tunes...
I appreciate your feedback billybix.
I've purchased my stang over a year ago and the high idle just started about 2 weeks ago. At this time, the only modification I have is the single Pypes Street Pro Exhaust, which I installed about 5 months ago. I have my Airaid CAI in route and will be delivered tomorrow.
Has your car been experiencing the high ilde issues since you got it?
I've been doing some research here on the forum and some people say it maybe the IAC or a vaccuum leak??? I am not very mechanically enclined and am not sure where to look for these.
Thanks again for your response!
I had the same problem on my '01 GT. There was a simple fix for it that fixed it right up. Maybe this will work on yours?
https://mustangforums.com/m_2625353/tm.htm
Believe it or not (this happened to me) the gas pedal and brake are unusualy close in the mustang and when you are braking the "side" of your foot is pressing the gas pedal.
Now whenever i get a high idle i move my brake foot and it slows down.
YoungStangsMan
09-05-2015 07:01 PM
Calizic
08-28-2015 01:46 PM
HIS S-197
08-10-2015 05:47 PM
