T-Loc & Gears vs GT takeoff rearend?
I've read that it takes a lot of know how to install gears and T-Loc correctly so would it be cheaper to buy a GT takeoff rearend than to buy t-loc and gears and have them installed? In other words would the parts and labor cost to install gears and t-loc in stock rearend be more than buying and installing the GT rearend with the t-loc and gears? Or would the costs be close enough that it would make more sense to buy and pay to haveGT rearend installed? That sounds complicated but I hope you get the gist of my questions.
And where would be a good place to buy the gears and t-loc for the stock rearend?
Thanks
Thanks
RE: T-Loc & Gears vs GT takeoff rearend?
This is an interesting question to me and one I have thought of. I think it depends on the quotes you get for labor. Lets take prices off of v6mustangstuff.com. For 3.73 and LSD would cost $450 plus shipping. For an 8.8 rear with the 3.73 gears and LSD on them it would cost 850 plus shipping. I think the rear end can be installed by anybody though somebody recently just did one. I think to get gears and LSD and to install them would probably be around $700 maybe $800 tops. But if you get the rear end then you don't have to worry about a crappy install and gear whine so I don't know just thought throw some numbers out there.
This is sort of a question out of left field but...
If you may end up going X-Charger or the like, wouldn't having an 8.8 rear solve some problems in the future? I'm not quite sure what I'm asking... And it will be until my warranty is out before I think about doing this. Thanks!
I dida 8.8 rear install about 3-4 weeks ago- now that I look back at it, the install wasn't too bad.
I liked the idea of knowing that the rear-axle was a factory assembled/inspected part, and had some use on it when I bought it. I got one for $225 locally and went for it.
COULDN'T BE ANY HAPPIER. No, i didn't really notice any change in acceleration because of the heavier axle. Also, mine came with 3.55s, which means it should have felt the same the way people were talking about how the heavier set-up will slow me down more... but it didn't. The car just gets up and goes!!! It would be more fun with 3.73s, but to be honest, I cruise at 80mph every day down my local freeways, and even with 3.55s it seems to be revving a little high for me.
So toanswer your question - it alldepends on your future plans. It's a factthat the 7.5in are going to be weaker than the 8.8s, but whether or not that applies to the actual horsepower potential of our v6sis up to you and your plans. N/A it should be fine. F/I might give you problemson a 7.5 t-lok. In the long run, you might be happier with a takeoff 8.8, as it is new (or very close to being), supposedly stronger, and will allow you more options for performance.
And what gears come stock with a 2007 Mustang auto?
i got ford 3.73's and frpp t-lok installed for my 7.5 and it feels great. if you intend on pounding it at the track, then the 8.8 makes logical sense. for the everyday driver, 7.5 upgrade is plenty strong. it come down to which you can get a better deal on.
anybody know what the actual weight difference is between the 7.5 and 8.8?
ORIGINAL: steveo555
Can someone explain to me more about this because I wanted to get 4.10's and I cruise at about 80mph
