I have an 07 with the aux input feature in the center console. I want to downgrade from my AVIC-D3 back to the stock stereo. If I buy an 05 Mustang stock stereo head unit, will the aux input feature still work? Because I know they didnt have the aux input feature till 07, so I'm wondering if an 05 or 06 head unit will work.
Also will I get my speed sensitive volume back?
Any help/info is appreciated.
Cut & Paste Expert
No, you wont. It needs to be an 07 model shaker
with a similar as built data as the OEM one you removed.
Otherwise, no AUX and it might not work right in your stang.
The speed sensitive volume will return with the installation
of an OEM shaker stereo.
I think the 05 and 06s had speed sensitive volume?
/\ +1 My 06 had the speed sensitive volume as well, along with an Aux output (I think) Its just laying around now since I had my Sony installed last year
thanks for the info. So I should definitely look for an 07 head unit? Also I dont have the shaker system, just the standard 4 speaker system. I think it will be impossible for me to find an 07 stock unit but there are plenty of 05s and 06s. I just really want the speed sensitive volume and aux to work. Does anyone know for sure what year unit I should get?
get an 07 unit and save a headache. the 06, like mine, has the aux button but no plug. its basically a worthless button unless you purchase an aftermarket adapter which will require you to rig up your own plug location. i went this route a while back. it worked perfect up until it screwed with my computer and made my instrument cluster go haywire. now i just use an FM modulator from Audiovox and it works great. static is non-existent.
edit: sounds like a good idea, I'll definitely look for 07's only now. Thanks for the info!get an 07 unit and save a headache. the 06, like mine, has the aux button but no plug. its basically a worthless button unless you purchase an aftermarket adapter which will require you to rig up your own plug location. i went this route a while back. it worked perfect up until it screwed with my computer and made my instrument cluster go haywire. now i just use an FM modulator from Audiovox and it works great. static is non-existent.
If anyone knows where they have 07 oem stock stereos, please let me know! I have a feeling I'm gonna be searching for at least a few weeks
Does anyone know if I have to get the stereo reprogrammed? I am probably getting an 07 unit out of a F350. Will the Ford dealer be willing to reprogram my stereo? How much does it cost?
Cut & Paste Expert
Quote:
ORIGINAL: dalbert
Yes, the dealer will have to go online and ORIGINAL: dalbert
download the 'as built data' for your VIN#
and load it into the OEM stereo so your 'can
buss' will recognize it properly.
I am not 100% sure but the Workshop manual
has the needed info you are looking for.
http://iihs.net/fsm/?dir=1
http://iihs.net/fsm/?dir=377&viewfil...dio%20Unit.pdf
Its called "module configuration".
Since you dont have the original radio for your VIN#,
the 'as built data' will have to be found by the dealer online.
Not sure of the going rate for stereo 'module configuration'
but at least you know what to ask for by name.
Module Configuration costs, please.
