oh damn...
Old May 25, 2008 | 06:20 PM
mustangman02232's Avatar
mustangman02232
Default RE: oh darnit...
i got mine for $370 off ebay look around
Old May 25, 2008 | 11:52 PM
1badV6's Avatar
1badV6
ur almost better just to buy and 8.8 with the gear of ur choice dont mess around with the 7.5 its weak and ur just gonna break it again even with a true trac ican promise you that an axle is like 900 slap it in and ur good ur still gonna spend 800 to 1k rebuilding ur 7.5 might as well put a good axle in it thats what i did and i dont regret it
Old May 26, 2008 | 12:01 AM
CroDalmatinac's Avatar
CroDalmatinac
A 7.5 rear end w/ a DTT is stronger than a stock 8.8...
Old May 26, 2008 | 02:06 AM
Legion5's Avatar
Legion5
ORIGINAL: CroDalmatinac
I thought that was only with aftermarket axles? By the way, did you get my PM Cro?
Old May 26, 2008 | 01:11 PM
mustangman02232
the axle shafts are the same for 28 spline on 7.5 and 8.8, the biggest advantage the 8.8 has is the ability to run 31 spline axles
a hardened set of axle shafts, a DTT, girdle, and girdle stud kit (all available at DTS posted above if you look around) and you will have a damn solid rear end that weighs a good 80 lbs less then an 8.8, there are a handful of sn-95 guys that have been running 7.5s with eatons/detroits with 400+ ft.lbs
and a stock 8.8 isnt THAT strong, ive blown the spiders out of a 8.8 tlok on a stock mach 1 which, even though they have 28 splines vs the 31s in the new ones. but fords parts are replacement parts, he even said he drives his car, hard, as he should, that along with the 20s i would try and stay clear of ffrp stuff
or find a wrecked GT with an 8.8 real cheap and throw a true trac or an eaton E-locker (posi unit that is an electric locker) but if you find aused 8.8 it should be rebuilt anyways
you cant really say get an 8.8 to have a stronger rear, if you do want a 100% no question asked bullit proof rear, get a 9"
Old May 26, 2008 | 02:17 PM
07lane40's Avatar
07lane40
u guys think theres any chance this will be covered under warranty?
Old May 26, 2008 | 02:19 PM
07lane40's Avatar
07lane40
FYI i have 17k on the clock and a little over a year having the car...
Old May 26, 2008 | 03:02 PM
GrayPony's Avatar
GrayPony
Default RE: oh damn...
ORIGINAL: 07lane40
last night my friends and i went out to just screw around and before i even got to my buddies house that we were meeting up at, i downshifted to first (i was going 10 mph), threw up the RPMS and dropped the clutch just to be an *** and have a little shot of acceleration, and this loud "'clunk clunk clunk clunk" happened.
You did a clutch drop and broke something ... whyshould it be covered under warranty?
Old May 26, 2008 | 03:23 PM
4.0 $tang's Avatar
4.0 $tang
BRING THAT SUCKER BACK TO THE DEALER.... TELL THEM TO FIX IT...ISN'T THAT WHY YOU GET A WARRANTY....I GOT THE EXTENDED FOR 75000 MILES....MY SALESMAN TOLD ME TO DRIVE IT LIKE I STOLE IT AND IF IT BREAKS BRING IT BACK
Old May 26, 2008 | 03:38 PM
mustangman02232
ford is just going to replace it with another open diff, go ahead it should be under warrenty, but you might be back in another 20k[8D]
and good luck fighting that one with the 20s on it
