Springs first or sway bars
I'm going to get a set of springs (Eibach Pros or FRPP N Springs)plus a set of sway bars (front and back; Helwig or FRPP).If I install the sway bars first will I have to turn around and partially uninstall them to get the springs in? Just looking to do the least amount of work.
RE: Springs first or sway bars
you don't have to uninstall the front sway bar for the front strut removal/installation. The rear sway is not very hard to work with.
i strongly recommend the use of upgraded shocks/struts with springs. it'll make things a whole lot easier - and it'll top off the suspension work you plan on doing.
i went with tokico d-specs, eibach pro-kit springs, and now i plan on ordering a helwig rear sway. i will be upgrading my front sway when i get the helwig... but to be honest the car already feels like a go-kart with i adjust the shocks to full hard!
I believe full suspension would call for a racing style setup:
coilovers,
sways,
bracing,
Adjustable panhard,
Adjustable lower and upper control arms,
Poly bushings,
and most importantly: TIRES.
coilovers,
sways,
bracing,
Adjustable panhard,
Poly bushings,
i upgraded my sways only and the difference is very noticeable. its a lot more fun to take corners now[8D]. i have no current plans for springs/shocks. the sways are enough for me at this point. i will be attacking the driveline again with an alum DS hopefully by end of summer.
A sway bar is a must have.
You should do both but if you do only one, the sway bar is first.
BTW, a sway bar in the back on a solid axle, will improve as much as you going outside and p#ss in the wind.
Save your money for the huge swaybar you'll need at the front.
