GT brakes vs v6
RE: GT brakes vs v6
No there is not.
The caliper brackets are different and the rotors are different.
Theactual CALIPERS are the same for the V6, PP or GT.
You need 2 caliper brackets part #6R3Z-2B134-B, the same left and right.
And some GT take-off rotors or GT aftermarket rotors.
The brackets come with the two one time use bolts from Ford and the
rotor removal is a snap after the retaining snap washers are removed.
Click on the thumbnail below for a pic of the clips. They can be
discarded after removal as they are only for assembly line rotor retention.
And you dont even need to bleed the brakes afterwords.
You also need 17" or better rims for the GT caliper brackets to fit.
Its a no-go with the stocker 16" rims. [:'(]
[IMG]local://upfiles/69445/E51F6A85689D4957A583021EC49A5628.jpg[/IMG]
RE: GT brakes vs v6
No. No difference in calipers.
The difference lies in the rotor diameter and the caliper mount brackets.
The GT rotor has to have a caliper mount that accounts for the larger diameter. The theory is that the larger diameter gives more leverage, thus more stopping power.
When I converted over, I also put new brake pads on. Biggest difference to me was instantaneous stopping power - but that can be noticed with just the replacement of brake pads.
^^^ I was beat to it [&:]
RE: GT brakes vs v6
ORIGINAL: fullmonte60
if the calipers are the same why does it have s197 v6 stamped on them?
and here are the brackets side by side
This is the bracket without the caliper sitting in position
And this is the full assembly
RE: GT brakes vs v6
Way to go JIM!!! Great pics of the install!! Thats going to make it easy. Do you remember offhand what you paid for those brackets? Did you get them from the dealership? I assume thats the only place to get them but, I hate dealing with the dealership if I don't have to.
RE: GT brakes vs v6
GT caliper brackets part #6R3Z-2B134-B
maybe $35 each at stealership
this includes the two 'one time use'
fasteners that will be required for
proper installation
these are brakes we are talking about
dont want a reused bolt snapping
during a hard braking situation []
RE: GT brakes vs v6
ORIGINAL: ptkthekid
The installation is very easy, and I think I have a write up on here from several months ago with all the pictures. You don't have to bleed the brakes since you use the same caliper - it is as simple as unbolt the caliper assembly, unbolt the bracket and substitute the new bracket. Then pull the retaining clip on the rotor and slide it off, slide the new one in place.
You will need a "C" clamp and block of wood to put the piston back in on the caliper and then slide it into place, bolt it back up - be prepared to pump the brakes when you start it up because the piston will be pulled back. It is a good time to upgrade your brake pads at the same time.
