high beam problems
Old Jul 15, 2008 | 08:35 PM
313stang's Avatar
313stang
Default high beam problems
Hey everyone, new to the forum and have a problem with my car. I have an'07 V6 and having isses with thehigh beams coming on allby themself.Clicking the differentials sometimes shuts them off. Took it to the dealer and they replaced the multifunction switch, I think they said it was in the steering column. Well they arestill coming on for no reason. Does anybody have any idea what the problem could be? This going back and fourth to the dealer stinks.
Old Jul 15, 2008 | 10:05 PM
cobrabobby's Avatar
cobrabobby
Default RE: high beam problems
Did the service dept also check the high beam relay? Could be
sticking.
Bob
Old Jul 16, 2008 | 10:44 AM
157dB's Avatar
157dB
Cut & Paste Expert
Coming on all by themselves.
Hmmmm.
High beams are controlled by the SJB.
Do you have the dreaded passengers side
water leak and your SJB has gotten wet?
Old Jul 16, 2008 | 06:58 PM
313stang's Avatar
313stang
Hey thanks for the reply. Not sure if they checked the high beam relay. I was thinking maybe it could be something along those lines, but not sure. I will mention it when Isee them Friday. I see there is a high beam fuse and a micro relay in the engine compartment fuse box. Never had any kind leaking. What is the SJB? Is itthe interior fuse box on the passenger side?No problems today, so we'll see. Thanks again
Old Jul 17, 2008 | 11:36 AM
157dB's Avatar
157dB
Cut & Paste Expert
ORIGINAL: 313stang
SmartJunctionBox =s interior fuse box located on the passengers side
kick panel. Check your carpet and pad for signs of water intrusion.
mungodrums
Suspension
May 16, 2019 09:36 AM
Pyrate Dave
Sep 10, 2015 07:30 PM
Sep 8, 2015 11:50 AM
zanemoseley
Sep 6, 2015 12:58 PM
