get a new gauge cluster to start
weather stripping is an easy and not a major repair.
why are you shifting your automatic manually? just put it in D and go.
+1 on the above....
and i wouldnt be shifting around on an auto.....i think i know what your trying to do....heh....i understand...but understand that if you mess with it too much you could hurt your tranny and that translates into $$$$$
as stated above...put it in drive and go....jhmo
Check for that passengers side water leak around the SJB area.
That could be the demise of your guages.
Are you throwing any DTCs?
Buy a manual if you want to drive like it is a manual.
i only shift it everyonce in awhile. lol im not shifting like a manual...+ i dont shift down EVER i just shift from 1 2 3 then drive...and i always do it from a stop. But a manual is on my wish list! as for the clusters...i have no idea what the abreviations mean... but ill look for leaks...could it be a fuse?
what are DTC's ?
what are DTC's ?
It's a trouble code. Do you have a handheld tuuner to read your computer codes with? If so you may find the answer to both of your issues by reading the codes the cars computer will give you. The tuner is an invaluable piece of hardware for these cars.
Couldn't he go to Advance Auto and they do a read for him?
He made have the dreaded leak and it may have fried some circuits.
ORIGINAL: 07 Stang
