Panhard & V6
Panhard & V6
Question for you guys & gals.
Since I put on my FRPP springs, my rear 7.5 axle has slipped to the left about .5-1" so I was going to the the BMR adjustable panhard bar. Before I order it, I noticed it says for GT, is this going to be an issue?
I will be adding Tokico D-specs also I would assume that won't affect anything as well.
RE: Panhard & V6
ORIGINAL: ODDYSEY
RE: Panhard & V6
.5" to 1.0" shift is impossable unless it was already shifted from the factory.
The panhard bar is about 44" in length at a 2 degree angle to the axle tubes.
Now drop the rear 1". Draw it out on paper and do the geometery.
Its only a 1/4" at best side shift.
RE: Panhard & V6
ORIGINAL: 157db
RE: Panhard & V6
You may end having toadd the brace as well. The stock brace is shaped like an upside down U. When you hit a large bump on the driver's side the springs compress and the stock panhard rod fits into the U. The adjustable brace has a large turnbuckle and it may not fit into the U and may bang when it hits the sides of the brace. The BMR brace rather than being shaped like an upside down U is flat and the panhard rod won't hit it and bang on it.
Install the adjustable panhard rod and after having driven it for a while, you'll know if it's hitting or not (you will definitely hear it if it does). If it doesn't bang, don't worry about it and keep the stock brace.
RE: Panhard & V6
ORIGINAL: Paleoc
UMMMmmmm,.......Yeah......What he said!!!
