PLEASE HELP ?!?!?!?!?!
Old Jul 29, 2008 | 06:10 PM
elroyjetson_1978's Avatar
elroyjetson_1978
Default PLEASE HELP ?!?!?!?!?!
I've been having a problem with the check engine light coming on at random times (once in the morning and several times in the afternoon at different spots). If I clear the codes sometimes it comes back on the next day and sometimes it skips a day. When it comes on it is always 0171, 0174, or both. I've taken off and readjusted the cai and I've cleaned the maf and I reflashed it with my new race tune from Bama. My SCT X-Cal 2 says this is system running too lean 1, or system running too lean 2. Has anyone had this issue or does anyone have any idea what might be causing it?[/align]
Old Jul 29, 2008 | 06:30 PM
ODDYSEY's Avatar
ODDYSEY
Site Moderator of Fury!
Default RE: PLEASE HELP ?!?!?!?!?!
Have you tried reflashing back to stock, then putting your tune back on?
Old Jul 29, 2008 | 07:32 PM
elroyjetson_1978
yes. and it is definately not the leaky window issue either cause I had the glass replaced in 2006 (rock from dumptruck)
Oh and the car runs like a champ before and after the light comes on
Old Jul 30, 2008 | 08:26 AM
ODDYSEY's Avatar
ODDYSEY
Do you have any other tunes you can try, see if it is your tune.
Old Jul 30, 2008 | 08:34 AM
mpatilla's Avatar
mpatilla
I'm a bit of a novice with newer cars, but could an O2 sensor be reading the ratio wrong? Does it seem to run fine?
Old Jul 30, 2008 | 09:24 AM
157dB's Avatar
157dB
Cut & Paste Expert
http://iihs.net/fsm/?dir=10&viewfile...scriptions.pdf
Old Jul 30, 2008 | 09:32 AM
rayrayl13's Avatar
rayrayl13
I had the exact same problem.... Call BBK and they will probably tell you that the actual intake tube isthe wrong size they had to discontinue a certain style of the tube because it was causing MAF problemsso theyll probably just send u another one and that should take care of it
Old Jul 30, 2008 | 04:51 PM
elroyjetson_1978
ORIGINAL: rayrayl13
I'll call them and see what they say but I've had the BBK cai on there since summer of '06 and it just recently started to throw the code. I'm wondering though if it is the cai cause when I first installed it it was pulled crooked but when I cleaned it recently I finally got the connector straightened out where the tube lined up with the tb perfectly
original current
O O
\ \l l
..O O
Old Sep 18, 2008 | 05:25 PM
monster2007's Avatar
monster2007
Im having the same problem now. I have an 07 and ive been having this problem for a year 6 months now. im out of state so i havent driven it yet. Have you found the problem and if you did please!!!!!!! tell me
Old Sep 18, 2008 | 07:29 PM
2005Redfire6's Avatar
2005Redfire6
Sounds like something with your sensors.
